Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
Mp258...can't print black with perfect...test print result no nice, black got missing line and color is great
McCuskerCo
  • 8 Answers
SOURCE: Color Printing Produces Pink Horizontal Lines
Hello we have had customers with this problem and this model printer We came upon this type of problem also exhibited the same lining when you did a nozzle check independant of the computer (not attached to computer and just using the internal head check print) This was a cartridge problem and after replacing the cartridge the problem stopped.
Posted on Jun 25, 2007
Blue Hammer
  • 167 Answers
SOURCE: HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Posted on Oct 19, 2007
jimmynuetron
  • 24 Answers
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Posted on Oct 24, 2007
SOURCE: prints black on test page, but not when a job is sent to the printer
I just posted and also fixed my problem. Try "deep cleaning" under the maintenance tab. Choose the black cartridge only. Mine only took once to fix but i'd try it 1-3 times before giving up on this solution. It now prints the test page with black and color
Posted on Nov 19, 2007
SOURCE: replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Posted on Mar 31, 2008
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
MFC-5860CN poor print test results, missing squares on test resu
I am not sure these have removable/replaceable printheads. I have had issues similar to what you describe. If one of the colors is missing completely, then it is likely that the head dried out due to prolonged lack of ink. If only a few squares are missing but all the colors are present, then you stand a better chance of unclogging. Cleaning 5 times is nothing. I've had instances where it took 20+ cycles to get a jet working. There is hope.
Jun 06, 2010 | Brother MultiFunction Center MFC-440CN...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Dell 3100cn
I've the same problem with a 3000cn but on the black color. all other colors are great execpt the black one.
Any Ideas someone ?
Apr 02, 2008 | Dell 3100cn Laser Printer
Blurred printing printer i255
Hi, check the nozzle and test , if the result not in solid color there are spaces within the color means need head cleaning after head cleaning twice test print .
Jan 23, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
414 people viewed this question
old marine
old marine
