Question about Sony 2GB Memory Stick PRO Duo Memory Card
Delete current images on stick without copying 2 computor
    Scholar:
  • 80 Answers
Hello and thank you for your question,
If your are trying to delete images on this memory stick without connecting the stick to the computer, all you will need to do is connect the memory stick to a compatible camera and select format memory stick.
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Wiz: zdeuyo
Posted on Mar 23, 2011
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
How do I change from internal memory to external memory on my camera?
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
May 09, 2011 | Sony Cyber-shot W290 Digital Camera
I have copied the files i want from the stick & want 2 delete the remainding 600 files without copying to comp.....
In the Camera's settings menu, there should be an option to format the Memory Card. Use this option.
Mar 23, 2011 | Cameras
Call of Duty Modern Warfare 2 for PS3. Getting
if you have a usb flash drive.
copy your game save files to it and delete the whole game including the saved games.
re-install and you should still have your saved game on the usb stick
copy this over and it should work.
if its the game save itself that is corrupted, then i'm afraid you have to start the game over again
Search 'how to copy ps3 game saves' and you'll find plenty of good step by step instuctions
Nov 22, 2009 | Video Game Consoles & Games
Cannot delete images from DSC P10
...just format the memory stick...but rememeber becouse all the picture inside the memory stick will all gone...
Jun 27, 2009 | Sony Part 996804671 Service Manual for...
How do I tranfer pictures from Kodak easyshare cx7300 built-in memory to a SD card?
Hi there, welcome to FixYa. I can explain that for you.
1) Put your card in the camera and format the card.
2) Go into the menu and set the camera's image storage location to the internal memory.
Then do this:
1) Press the Review button.
2) Press the Menu button.
3) Scroll up or down to highlight Copy.
4) Press the Ok button.
5) Press up or down to highlight an option
5) ALL to move everything (pictures & video) to the other location (the card). - Picture or Video to move the current item to the card if you just want to move one thing at a time.
By the way. This will only COPY the images or videos to a card. They will still be in the camera's internal memory. If you want to delete them you have to follow the Delete images procedure.
To Delete:
2) Scroll Left or Right to find a picture.
3) Press Delete button
4) Scroll Up or Down to highlight an option.
The ALL option will delete everything.
5) Highlight Exit and Press the Ok button.
That will cover it. Thanks for coming to FixYa and feel free to rate my solution.
Rob
Mar 06, 2009 | Cameras
How do i transfer the files to memory stick. without softwear. my computor is showing new hard wear.
Go to My computer on desktop. You will see the icon of the memory device. you can now drag and drop or copy into this.
Jul 05, 2008 | Computers & Internet
How to?.....
You should be able to transfer the images directly to your computer without transfering them to you memory stick duo. Have you tried connecting the camera to your computer and retrieving the images? If you would rather have the images on your camera on your memory stick duo, then remove the memory stick duo connect the camera to your computer, copy the images off of the camera, turn the camera off, put the memory stick duo back into the camera, plug the camera back in, then transfer the images that you just transfered from the cybershot to your computer back to the camera. They should copy directly to the memory stick duo.
Feb 24, 2008 | Cameras
Sony Cybershot DSCW1 - Removable Storage?
Some cameras can't do that. I have a HP that only is noted and usable with HP's software. Yours may be one of those type cameras. In your post you want a feature that may not exist. So you may have to get a card reader.
Sep 08, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Deleting Photos From The Memory Stick
Deleting Still images From The Memory Stick This procedure is nearly identical with all of our digital camcorders. The only difference you may find is that there may not be an enter button on your model. If this is the case, the menu dial serves as your enter button when you push it in. * If you want to delete protected images, you must first deactivate the image protection. * An image which has been deleted cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. 3. Using the (FWD) and (REV) buttons, search for the still image that you want to delete. 4. Press the MENU button. 5. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The MEMORY SET submenu will appear. 6. Turn the MENU DIAL to highlight DELETE and press the ENTER button. Using the MENU DIAL, select either THIS FILE or ALL FILES and press the ENTER button. *THIS FILE : deletes only the file currently selected. *ALL FILES : deletes all files stored in the Memory Card. 7. A box will appear to verify whether you wish to delete the image(s). Using the MENU DIAL, select the item. *EXECUTE : deletes the selected image(s). *CANCEL : does not delete the selected image(s) and returns to the previous menu.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony 2GB Memory Stick PRO Duo Memory Card Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
