Question about NetGear WGR614 Wireless Router
Just purchased a WGR614 wireless router for my dell laptop. the instruction manual only mentions connecting to external modem, what if you have a laptop with an internal modem, how do you connect? My laptop is not even detecting the router?? I don't know what I'm doing....PLEASE HELP!!!
    Sergeant:
  • 223 Answers
Thank you for using FixYa
Wireless connections have a lot in common so here is a link that will give you the general configurations for a wireless Router to PC. Keep in mind that you will need to configure both the computer and the router in two separate steps. That is why it is best to use the setup disk that normally comes with a new piece of equipment and the cables.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Also keep in mind that the equipment should be matched or designed to work with the other equipment. You will have some kind of a modem either a cable modem or internal modem or external modem that the router will have to connect to.
It is best to allow your own Internet Service Provider to set up the connections. They may not be able to support the configuration if you do not purchase it from them and then you will need to do-it-yourself.
Here are the links for configuring the computer with the different operating systems
Win XP http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/wlan_client_configure.mspx?mfr=true
Win Vista
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
Win7
http://windows.microsoft.com/en-US/windows7/Setting-up-a-wireless-network
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 23, 2011
I purchased a WGR614 Wireless Router and it won't go past step 3 on the installation because it says that my login information is incorrect after identifying it as a static IP address.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 20, 2010 | NetGear WGR614 Wireless Router
I have a Wgr614 and a dell laptop computer. The only way I can access the internet is by directly attaching the ethernet cable to my computer. I need to mention, I removed a Trojan last night with...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 21, 2010 | NetGear WGR614 Wireless Router
Router setup
Then you need to connect the computer to the router ad the modem to the router.
Jan 28, 2010 | NetGear WGR614 Wireless Router
WGR614 v6 Fails to connect to internet, no wirelss signal
mabey there is a problem with the LAN cable or a connection error
Dec 12, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Nov 26, 2008 | NetGear WGR614 Wireless Router
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
62 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
