Question about Compaq Computers & Internet
I am having difficulty booting up the computer. The computer will only power up if I switch the power bar on and off several times.
  • 81 Answers
Maybe the power cord from avr to cpu is not set tightly please set it up. second maybe your avr has no power output try to plug power cord direct to the power outlet.
Posted on Aug 03, 2008
My notebook will not boot properly, and date and time resets.
please use this small secret. Disconnect the power adapter from computer 2) DISconnect the battery from laptop.
3) Press the main button power for 60 seconds exactly. This method discharge any ESD. keeping in the system. and try again, will be work.
However if the problem persist see the flow charts. attached.
Mar 06, 2013 | Computers & Internet
Tip
How to Reset BIOS on the GA-X58A-UD3RMotherboards often include hundreds of...
How to Reset BIOS on the GA-X58A-UD3R<span style="font-style: italic;">Motherboards often include hundreds of settings in the BIOS to adjust the performance and stability of your computer. Many of these settings, when improperly configured, can prevent the computer from booting. The traditional way of resetting the BIOS when it doesn't boot is to open the case and place a jumper on the motherboard or remove the battery for several minutes. Most newer motherboards include a reset button near the peripheral ports. The Gigabyte GA-X58A-UD3R uses this more convenient method.</span><br /><br /> <span>Instructions</span> <ol style="font-style: italic;"> <li>Power down your computer by selecting "Shut down" in the Windows task bar or press the power button on your case for four seconds. Leave the power cable plugged in and the switch on the back of your case in the "On" position.</li> <li>Press the "Clr CMOS" button on the back of your computer for five seconds until the computer boots. The button is located with the peripheral ports between a USB port and the coaxial S/PDIF port.</li> <li>Press the "Delete" key when your computer starts up to enter the BIOS setup.</li></ol> <ul style="font-weight: bold;"> <li>Pressing the "Clr CMOS" button while the computer is powered on could result in data loss.</li></ul><br /> <span><span>References</span></span><a href="http://download.gigabyte.us/FileList/Manual/mb_manual_ga-x58a-ud3r_v2.0_e.pdf">GA-X58A-UD3R USER MANUAL</a><br /><br /><br />*please leave a ratings if this information is helpful and beneficial to you.<br /><br /><br />Regards<br />MultilinkEnt. <br /><br /><br />
on Jul 09, 2011 | Computers & Internet
My desktop pc cannot boot again, it keeps on showing disk read error.
if its showing disk read error then possibly there is some problem with your hard drive or RAM. there are more chances that you have to change your hard drive.
but you can try one thing just boot the computer using a bootable windows disk and try to full format the hard disk and then install the OS. it should help.
but if there are bad sectors in your hard disk then it seems that you have to change your HD.
Jan 06, 2011 | Dell Computers & Internet
Desktop with A8V-E SE motherboard will not boot
does the monitor light up when turned on if no recommend completely new computer M/board and CPU as this is the quickest and probably the cheapest way out of your problem.
time spent trying to fix old one is costly per hour spent
any water near M/board is fatal you only need 1 connection with water and that is that
Feb 27, 2017 | ASUS A8V-E SE Motherboard
Photo keychain wont turn on
was a problem w/USB cable. Got it fixed. Wasn't fully inserting into keychain.. Now works great.
Dec 31, 2008 | Tao 1.5-inch Square Polished Silver Photo...
Dell gx270 power switch
I don't think you need a new switch. The power "switch" on the front of computers today is a momentary action push button switch. Not a locking or clicking switch as older computers used to have.
Many of today's computers, including the gx270 / gx280 computers from Dell are really always on. You can see the green or yellow LEDs on the motherboards glow when they are "off" (like a sleep mode).
They are in a "sleep" mode until you push the power switch, which sends a momentary signal off to the motherboard to fully power up and turn itself "on".
I think you have something else happening here. When the system tries to power itself up, and detects a severe problem, it will try to automatically turn itself off.
The problem could be a bad motherboard, power supply, memory or processor. It could even be a failed hard disk that is drawing too much power (shorting out) from the supply.
If you had done something to the system, like move it or open it up for an upgrade, etc.. Look again at all the internal connections, and make sure there is nothing rattling around inside that might also be causing a short.
You could try removing all the PCI cards in the system, removing the power and data cable connections from all the disks (Floppy, Hard Disk, CD/DVD) and see if the bare motherboard (with CPU and memory) will boot by it self. If it does boot, then the problem was somewhere in those items and you can replace them one at a time until you find the problem, or if it all works again then it may have been a loose or bad connection.
If you have another machine available, you could try switching the power supplies and seeing if that is the problem.
-Chip
Nov 21, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Precision M70 PC booting problem
There’s probably an issue with your boot-up files or the hard drive. Suggest you start backing up all your documents, pictures and anything else that you don’t want to lose. Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. If no errors are detected, your software has a problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 26, 2008 | Dell Precision M70 Notebook
Sonicwall Firewall Pro2040 Boot Issue
If you do not see connection lights, you might be connecting the Sonicwall directly to a computer, instead of to a switch.
Try using a crossover cable, or try plugging the Sonicwall and your computer both into a network switch.
Jun 08, 2008 | Computers & Internet
Boots halfway and dies
One from all problems can be:
Hdd problem or power suply
If u have another hdd change it and try
Let me know if u got help?
Nov 27, 2007 | Dell Inspiron 1100 Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
