Question about Brother DCP-110C All-In-One InkJet Printer
My printer wont clean, and i dont have the troubleshoot manual on me, What do i do?
Ink tanks full but blue ink wont print on my Canon MP190
clean the heads if that dont work clean the inside where the cartridge goes in and if that dont work buy a new ink otherwise get new printer
Feb 19, 2015 | Canon PIXMA MP190 All-In-One InkJet...
Pixma mp210 how to manually clean print heads
see manual for maintenance tools in cleaning print heads or maintenance tab in printers and devices for head cleaning. dont do it manually. you might damage the cartridge
Aug 12, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Hi my black ink wont print i have done lots of head cleaning and replaced cartridge with a new one but it still wont print? the printer is only 12 mth old and i really dont want to have to buy another one...
Well you dont say what model printer you have but I suspect that it is either a canon or brother.
If it is a brother, forget it and throw it away as the cost to repair is more than printer is worth.
If it is Canon then you have a defective printhead and no matter what you do you will not get it to print the black.
The printhead is situated under the ink cartridges. Remove the cartridges and then you can remove the printhead. You can try steaming the printhead but it wont redeem it. Unfortunately the cost of a new printhead is more than the cost of a new printer.
Jun 10, 2011 | Office Equipment & Supplies
The printer won't function at all. It keeps saying "unable to clean" It also says to look at the Troubleshooting and routine maintenance chapter of the user's manual, however i dont have the user's manual.
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
check the brother website for an authorized service center
Jun 16, 2010 | Brother MFC 420CN All-In-One InkJet...
Full of black ink & need to print black. other colors are low, and it wont print!! I dont need the other colors
I ran this process two months ago when the printer was 4 months in use.
Try running through the manual cleaning process for the print heads.
1-press ink
2-choose cleaning
3-choose ALL. If that doesnt work try cleaning BLACK only.
when the cleaning finishes the machine will go back to standby mode automatically.
see pg 172 in users manual under routine maint.
Jun 16, 2010 | Brother MFC-640CW All-In-One InkJet...
CLEANING SHEET REQUIRED FAULT
go to options and find cleaning sheet im thinking the jets are full of gunk... it is an option (cleaning sheet) i just dont have the printer near me but it is ill try to go out there and get you specifics but if not its under print quality options...xerox.com has some things u can try also
Dec 15, 2009 | Xerox Phaser 8500/DN Printer
Can Someone Help?
If you installed new cartridges in teh color slot and it will not print from the computer in color, go into the printer setup menu, a button on the printer should take you here, and print an alignment page. If this fails to print correctly, select to perform a deep cleaning. This will use a lot of ink but will insure your nozzles are working correctly. If nothing prints or the color still isn't correct you will need to either manually clean the nozzles or have someone clean them. To be honest, depending on the cost of the printer it maybe more cost effective just to get a new printer than to have your manually cleaned. As inexpensive and printers are today I don't even replace cartridges anymore except for the black one. When the color runs out I get a new printer. The printer runs 35 to 39 dollars the color cartridge runs 35 to 37 dollars. But I don't do a lot of color printing. It is a choice the individual has to make.
Aug 28, 2009 | Dell A940 All-In-One InkJet Printer
Maintainance
go to www dot brother dot com and search for the model number. user manual should be there.
Oct 09, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
