Recently my subwoofer blew out & a friend hooked up a Bose subwoofer that goes to a computer,i think it was defective because when he hooked it up something inside my reciever just started to smoke so i pulled the plug from wall before any serious damage was done to it. but now when i plug it back into the wall it lights up & stays on for afew seconds then automattikly shuts off but the power light just blinks. i've done everything the instruction book told me to do but it won't stay on. i think i need to dial the code no.in so that it works again & that i dont have...
    Brigadier General:
  • 8,546 Answers
Put a fork in it, it's done. Take it a tech to give it the sniff test and determine the extent of the damage.
If you want a specific answer regarding a code you need to provide a make and model number. I doubt any code will negate whatever caused 'smoke'. No UNDO buttons on this stuff.
In the future refer to manuals for speakers and amps before randomly attaching parts of other brands or packages' all-in-ones'. They're usually desigend to be used exclusively as one unit and are not generally interchangeable.
Posted on Mar 23, 2011
Best way to hook up Bose 901 series VI to a Harman Kardon HK3490
According to the HK site, "Stereo pre-amp outputs let you connect the receiver to an external power amplifier." So it's easy. Connect the Bose equalizer in the pre-out / amp in loop.
Nov 07, 2015 | Bose Audio Players & Recorders
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
How do I hook up a bose subwoofer in a non bose 2000 Cadillac seville sls?
I would hook up an amplifier first, then hook the sub up to the amp.
Jun 23, 2015 | Cadillac Cars & Trucks
How to hook up bose 901 active equalizer to onkyo grand integra pre amp?
You don't.
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
Sep 01, 2014 | Audio Players & Recorders
Alpine x is not reading proper ohm resistance amps blew
the gmax amps are only 2ohm stable. it is odd that they both blew at the same time but if the impedence is too low to amps will fail.dual 4ohm dvc subs wired in parallel should read around 2ohms. allthought impedence varies with frequency and isnt truly stable.
Feb 12, 2010 | Alpine SWX-1042D Car Subwoofer
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Subwoofer not working properly after a few mins playing
Get a hold of the woofer connector (I believe its brown) right by the whoofer and move it around/press it/disconnect and reconnect and check if the woofer comes on. There is a bad connection in the connector for the woofer itself. I have a 2001 GLE my self and that's what I found to be the problem with mine.
Dec 16, 2008 | 2001 Nissan Maxima
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Jul 01, 2007 | Hifonics BX1500D Car Audio Amplifier
Help!!!!
Check your ground wire! Relocate it to another place in the car and try to get a heavier ground wire aswell.
Apr 03, 2007 | Sony XM-2200GTX Car Audio Amplifier
 Grubhead
Grubhead
