I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have downloaded the driver for Roland Camm-1 CX-24 compatible with Vista from the Roland website. This cannot be installed as Vista with USB so I was given the instruction to install it to port LTP and then try and print a sample going through each port on the list in turn until the printer reacted. I cannot get the printer to react. Every port comes up with printing error apart from COM3 and USB003 which do nothing at all and it doesn't seem to communicate. Any advice on what I'm doing wrong? Is it the cable, the Vista or the method? Thanks Laura
  • lauracowley Aug 03, 2008
    Roland has Parallel socket to connect to. My PC is laptop and so does not have parallel port, I must connect by USB. I have a USB to Parallel port cable to do this but it doesn't seem to work.
    Thanks x
  • forge signs Nov 07, 2008
    i had an old computer were my motherboard blew so i have just bought a new computer but does not have a parallel connection on the back does it work on usb?? and what does the dongle do??
Connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Posted on Apr 16, 2009
I'VE FOUND THAT THE CUTTER DOESN'T SUPPORT THE WINDOWS NT FILES.
Posted on Jun 28, 2012
Hi Just managed first cut using usb port. from what i gather the problem is with the program and not the usb interface. software i managed to get working was flexisign8, tried corel but failed.
Jonathan Hickman
Posted on Apr 28, 2009
  • sitbackandla Feb 01, 2012
    Iam working on same problem...was wondering what ya did cause I still can't get cutter to work off usb with flexi. Any help would be great. Thanxs
Hey guides pls help me i have the problems with my roland cx-24 cutter plotter,i want use in xp but it
does not supports xp only for 98,i want to run in xp so pls iwant a drivers
Posted on Nov 10, 2008
  • 81 Answers
Your operating system is windows vista and the port supported by your roland camm-1 is parallel and com port? and do you have a parallel port on your pc? if you have a parallel port on your pc you connect from there that is LPT port. and install the driver.
Posted on Aug 03, 2008
SOURCE:
Roland Camm-1 CX-24 Error Er15:RS-232Err How do I fix this? Thanks John
Could you let us know when this error pops up. and what all you have tried
Thanks
proton
Aug 02, 2008 | Computers & Internet
Dell inspiron 1720 vista admin password recovery?
If you are running Windows 7, if you type in the wrong password once, it normally says reset password... below the box for the password. Insert a removable disk (such as USB, floppy disk, etc.)
and follow the prompts.
Oct 25, 2013 | Computers & Internet
Can someone tell me how to use my Roland CAMM-1 CM300 Pro vinyl cutter with Windows Vista as it's a pretty old machine and I think will only work with Windows 98
You should Buy a newer Model, Vista will not detect it. That is why Vista was a mistake... I like Linux Computers much better
Sep 25, 2013 | Computers & Internet
I have left and right handed dell a215 speakers but don't know how to connect them
you might need a usb to speaker adapterhttp://www.ebay.com.au/itm/USB-2-0-MIC-Speaker-5-1-Audio-Sound-Card-Adapter-/120645945426?pt=AU_Laptop_Accessories&hash=item1c170f0852
hope this help
Jul 21, 2012 | Dell Inspiron 1720 Notebook, Windows Vista...
I have a DELL Inspiron 1720 with windos vista. I am trying to install windows 7 but it is showing me this message: OEM Name : DELL INC OEM model: Inspiron 1720 BIOS version: Phoenis ROM BIOS plus...
You need to check the specifications of your laptop it may not be able to run Windows 7.
You need these specs:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Sep 17, 2011 | Dell Inspiron 1720 PC Notebook
Suddenly no sound on my dell inspiron 1720, vista, sigmatel
COPY UR IMP DATA O OTHER DRIVES AND FORMAT UR WINDOWS.
BEST SOLUTION.
AND DONT INSTALL UPDATES
May 17, 2009 | Dell Inspiron 1720 Notebook
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
Computers & Internet Logo
5,035 people viewed this question
Alun Cox
