Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
Dryer will not start when pushing start button it just clicks once
    President:
  • 1,554 Answers
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Posted on Mar 23, 2011
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
I have a Whirlpool Dryer model GEW9200LW1. I have to push the start button 10-15 times to get it to start, then it may run 1 second to 20 min and just shut off with time in the display. then if i push...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Whirlpool Dryers
LG Steam Dryer (DLEX3001R) won't start
Do you have 240 present at dryer. If so then check the belt and blower.
Oct 06, 2017 | LG Dryers
Dryer wont start.
Some start buttons do not click. But it sounds like maybe the door switch.
Sep 25, 2009 | Kenmore 659 Electric Dryer
Wont start
Is the motor running but the tub not spinning? You can tell by feeling for air movement out the exhaust after you start it or by listening to the dryer (put your ear against it and listen for a humming sound).
If motor is running your belt is broken and will have to be replaced.
Sep 02, 2009 | Dryers
Dryer won't start
dead dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Dryers
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Fuse
Your belt is broken, the click that you hear is a centrifugal switch that shunts your start button, so we know the motor is running. Check your belt.
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
2,949 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
