Question about Westinghouse Washing Machines
Westinghouse lt609s Washing machine has stopped and will not progress HC error
  • Westinghouse Master
  • 17,130 Answers
Possible fault in the main program controller unit. It is important to test the sequence and output of the program , the voltages to the motor during the wash cycle drive motor, the input valve and output valve voltages at the point of cycle to confirm the program controller.
Posted on Mar 23, 2011
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
Error 33 in Hyundai hc 1007w Washing machine
E 70 hyndai washing machine hc-1700w
Mar 16, 2017 | Washing Machines
My usually trustworthy Westinghouse LT609s won't start cause it says the lid is open when it's not. Is it done for?
not necessarily
it could be the out of balance lever on the wrong side of the lid switch
lid switch or program board
before you make a decision to junk it ,have a technician check it out and get a quote to fix
Dec 28, 2015 | Westinghouse Washing Machines
I keep getting the error message top-au followed by weird sounds on a westinghouse sensor drive
I tried to research this error but came back with no results. I would contact Westinghouse and talk to their support team.
May 08, 2012 | Westinghouse Washing Machines
I have a westinghouse washing machine LT819S with error code 3f any segestion how to fix
If water is not filling then it can be the failure of the inlet valve, if water fills but does not stop the error can be the water level sensor and if the motor does not work with voltage to the motor, it is failure of the motor.
However if there is no response at all then the control board is faulty.
Sep 13, 2010 | Washing Machines
Model LT609S Washing Machine Bad Smell After Washing
A problem like this can be difficult to resolve using cleaning solutions alone.
See this FixYa Tip for some strategies that work well in eradicating mold which is the main cause of this problem.
If you find the solution helpful please leave a vote for it. Thanks.
Apr 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Westinghouse washer lT609s - tap problem
if I understand you correctly ... your washer keeps filling with water and you must shut them off at the wall to stop the water from coming into it?
this is a stuck water valve .. there may be something in your water valve keeping it open...
unhook your hoses and check them..
hope this helps
Apr 05, 2008 | Washing Machines
Washing Machines Logo
387 people viewed this question
Top Westinghouse Washing Machines Experts
Mack Baxter
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
