When I try to boot my desktop I get a message saying tge fololowing file is missing or corrupt - \system32\ntoskrnl.exe. I can not boot using the F8 key either.
  • Gayle Ashbach
    Gayle Ashbach May 11, 2010
    Your files have become corrupted in some way. What windows version do you have and what operating system CDs came with your system?. You may have a recovery disk or just an operating system disk (Windows XP or...) Do you have a manual? for your windows system? If not you may be able to download one at www.microsoft.com/support. I need more infomation to give you exact instruction of where to go for help.
  • 81 Answers
Do you have two hard drives? if you have two check the power on the primary hard drive maybe it is not fit properly. second the windows you have is corrupt. you may reinstall your windows.
Posted on Aug 03, 2008
How can i reinstall the ntoskrnl.exe when it is corrupt
Assuming a couple of things:
1. Your OS is Windows XP
2. This is the error message you are getting -
"Windows NT could not start because the following file is missing or corrupt:
Winnt_root\System32\Ntoskrnl.exe
Please re-install a copy of the above file."
To reinstall notskrnl.exe, do this:
  • Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  • After the setup files are finished loading press R to repair using Recovery Console.
  • When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  • Login to the Administrator account by typing the password for this account, and then press ENTER.
  • At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    For Multi-Processor systems:expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
    Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  • If you receive a prompt to overwrite the file, press Y.
  • Type exit, and press ENTER at the command prompt.
  • You should now be able to boot up properly.
  • Oct 14, 2013 | Dell LATITUDE Computers & Internet
    I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
    NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
    Related errors
    Below is a listing of the full error message that may be related to this error.
    Windows NT could not start because the below file is missing or corrupt:
    C:\Winnt\System32\Ntoskrnl.exe
    Cause
    1. Keyboard issue
    2. Miscellaneous corruption
    3. Corrupt boot.ini file.
    4. Missing boot.ini file.
    5. Missing or corrupt ntoskrnl.exe file.
    6. Windows NT installed on a partition bigger then 7.8GB
    7. Corrupted hard disk drive or severely corrupted Windows.
    Solution
    Keyboard issue
    This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
    Before trying any of the below recommendations it's recommend that you load the last known good configuration.
    This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
    Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
    Microsoft Windows XP users:
    If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
    Microsoft Windows NT and Windows 2000 users:
    To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
    1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
    2. In the setup menu, type R to start the repair.
    3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
    If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
    2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
    3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
    4. Select the operating system you wish to fix, and then enter the administrator password.
    5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
    6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
    7. Type exit to reboot the computer.
    If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
    OS Loader v4.01
    Disk I/O error status=00000001
    Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
    Please reinstall a copy of the above file.
    If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
    Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
    5. Once at the recovery console type chkdsk /r
    6. Once completed type exit and see if issue is resolved.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
    Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
    http://www.computerhope.com/issues/ch000646.htm
    Mar 02, 2012 | Gateway GT5026E PC Desktop
    <windows root>\system32\ntoskrnl.exe.
    Feb 11, 2010 | ASUS MPM1 (ASS5200) PC Notebook
    Windows\system32\ntoskrnl.exe filie is missing or corrupt.
    need to reinstall windows cause the system files for the operating system is corrupt.
    On your compaq, keep pressing F10 as you turn on the computer and that should take you into the factory restore.
    If you can't get into that then you'll need an operating system cd and then download the drivers off of the compaq website: partsurfer.hp.com
    Jan 11, 2010 | HP Compaq Presario SR2020NX PC Desktop
    <Windows root>\system32\ntoskrnl.exe.
    Do you have a Windows CD that came with your computer? If so do you know how to boot from it by inserting it into the drive and then pressing F12 just after you switch on your PC? If you can do this then you could try the "repair" option from Windows Setup, this might fix your missing PC problem.
    May 17, 2009 | Compaq Presario 700 470024-192 Notebook
    I have a IBM thinkpad that say at start up the following message. windows could not start because the following file is missing or corrupt. <windows root>\system32\ntoskrnl.exe. please reinstall a...
    Assuming that you are using Windows XP, the easiest solution would be to boot from your XP cd and do a system repair. Please let me know if you need more info on how to do this.
    Nov 30, 2008 | Computers & Internet
    Error: windows root>\system32\ntoskrnl.exe
    Issue: NTOSKRNL.EXE is missing or corrupt.
    Related errors:
    Cause:
    1. Keyboard issue
    Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
    Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
    Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
    Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
    Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
    Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
    Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
    Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
    If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
    Oct 18, 2008 | Computers & Internet
    How do I...
    Related errors:
    Cause:
    Keyboard issue
    Solution:
    Keyboard issue
    OS Loader v4.01
    Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
    ACER DESKTOP COMPUTER
    Related errors:
    Cause:
    1. Keyboard issue
    best regards wish u give me a good rate ^^
    Aug 15, 2008 | Acer Computers & Internet
    Open Questions:
    Computers & Internet Logo
    88 people viewed this question
    David Payne
    David Payne
