Question about Philips Office Equipment & Supplies
My phillips laser mfd 6020 continually shows the message ""paper empty" although there is a stack of paper in the machine. What am I doing wrong?
  • Philips Master
  • 17,130 Answers
The paper feed is detected with a INDETECT sensor/switch and if this is faulty the message will be shown. Also if there is a fault or error in the main board or processor this can be seen.
You can try and remove the panel and get access to the inner tracks to check the sensor , make sure that all connections are tight and there are no loose connections.
Posted on Mar 23, 2011
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
How do i download and install my philip laser mfd 6020 printer
Go to Philips.comsupport, and click on "contact". Have the full product number available. Pose your question to Philips. Usually going directly to the source, will bring you the best results.
Jan 04, 2015 | Laser Office Equipment & Supplies
The printer continues in Self Test, the printer is stuck at this point as it tries to continue to cycle through the power up.
Try to power on the printer without the toner kit and the waste toner box. If the printer stacks again at self test. Next step.... remove one part at time and check if the printer displays any message. First remove the developer unit and power on the machine (normal message "Missing Developer Unit"). Then pull out the fuser unit and power on the machine (normal message "Close Rear Cover"). And finally, remove the Drum Unit and power on the printer (normal message "Call Service 7410").
If the printer still stacks at Self Test, then that is not a good sign. Try to upgrade the printer' s firmware (system + engine). There is a possibility to go further from Self Test.
If it does not, then you have to replace the main pwb.
Oct 28, 2014 | Kyocera Fs-3920dn Laser Printer
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
Samsung scx-4248FN will not print. it shows "manual feeder paper emtpy" there is paper, I added more, I turned it off and on twice??
Presume that the paper sensor stopped working. If after reset it still "reuses" to recognize it has paper, you should take your printer to a repair service.
If you have some doubts about my answer, continue your quesry
Dec 13, 2012 | Samsung SCX-4828FN All-In-One Laser...
How do i connect my philips laserMFD 6020 printer to my computer without a cd?
Without a CD, first of all you need to go on google and search for philips website. Enter your product as Laser MFD 6020. This will take you to a page where you will see all the info on it including software and drivers with an option to download. Once you download, connect your printer to your computer using a USB Cable. After that reboot your computer should detect it and follow the instructions to install. I hope this will help.
Jun 26, 2012 | Philips LaserMFD 6020 (LFF6020)
I am having problems with my printer feeding the paper. I have tried to unplug from the power source, turn off the machine and have tried buying different higher-grade paper. If I unplug and then plub...
I have the same printer. My solution is never fill the paper tray completely full only about 3/4ths full and never let it get below about a quarter from empty either (I put in a bunch of already printed on pages for the bottom 1/4th of the stack and when those start to print I know its time to add more paper. You can have the tractor feeder replaced (that is the part that sucks up the sheets of paper from the stack) and that will fix your problem but the quote that I was given on mine to fix it was more that the printer was worth.
Aug 25, 2010 | Konica Minolta magicolor 2400 Laser...
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Hi I bought a new printer Philips Laser MFD 6020 but I am unable to install as the CD is not helping, since it said cant find the hard drive.
Go to this site and download the drivers for your printer.
ptf.com/philips/philips+laser+mfd+6020+drivers
May 19, 2010 | Office Equipment & Supplies
484 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
