Digital reference dr-t15 transmitter/audio tecnica. both on but light is on and levelss up!
Can beats s450 be connected to any soundbar?
If the soundbar is Bluetooth-enabled, yes. But I have not read or heard about a Bluetooth-enabled soundbar yet. And why would you want to connect the headphones to the soundbar ? The only situation where this would make any sense is if the soundbar were hooked up to a TV. If this is the case, your only solution is to use regular (not Bluetooth) wireless headphones, which consists of two pieces: the headphones and a transmitter that you hook up to the audio output of your TV. The transmitter piece transmits any sound coming out from your TV wirelessly to the headphones.
Sep 27, 2014 | Beats By Dr Dre - Wireless Bluetooth...
Connecting mp3 car radio
If you radio has an Aux input then you can connect a audio cable from your MP3 player to the Aux input on your radio.
If your radio does not have an Aux input the you can use a FM transmitter device. Connect the MP3 player to the FM transmitter and tune your FM radio to the radio frequency on this FM adapter to listen to your audio book on your MP3 player.
Check out these WEB sites fro FM transmitters.
http://dx.com/c/car-accessories-799/car-audio-systems-707/fm-transmitters-players-710
http://www.amazon.com/Coby-CA-745-Wireless-Transmitter-Cigarette/dp/B000OTF6G0
http://www.popularmechanics.com/technology/how-to/gadgets/4307160
Feb 05, 2013 | Audio Players & Recorders
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
I cant get the receiver open to put the batteries in to the Digital Reference DR-2606
Your receiver runs on an external power adapter. I think you meant the hand held transmitter.
Hold the top metal mesh dome of the Mic and twist the lower casing anti clock wise. The Tubular cover will come off and you will see a battery compartment into which you can insert 2 AA cells.
Mar 11, 2011 | Digital Reference DR-2606 Vocal Wireless...
Sound cast will not play from my ipod by wireless green light on speaker blue flashing light in the transmitter
Usually this happens when you have a damaged power supply. Once you replace it everything goes back to normal. You can contact tech@soundcastsystems.com for support on this.
Dec 01, 2010 | Digital Media Soundcast ICT-111 iCast...
My Teac DR-H300 will not open the dvd drawer anymore. It looks like the magnet won't release on the drawer. Can anyone tip me what to do?
I solved this by holding the power button down for 5-10 seconds. After a reset the drawer opened as normal.
Dec 05, 2009 | Teac Reference DR-H300
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Programing garagedoor opener
HOMELINKT UNIVERSAL
TRANSMITTER (IF EQUIPPED)
The HomeLinkt Universal
Transmitter, located underneath
the driver’s visor, provides a
convenient way to replace up to
three hand-held transmitters with
a single built-in device. This
feature will learn the radio
frequency codes of most current
transmitters to operate garage
doors and gates, and can also
control home or office lighting and
security systems (with the
available accessory package).
NEXT
MODE
Controls and features
42
When programming your
HomeLinkt Universal
Transmitter, you will be
operating the garage door or
gate. Be sure that people and
objects are out to the way to
prevent potential harm or
damage.
Do not use the HomeLinkt
Universal Transmitter with any
garage door opener that lacks
safety stop and reverse features as
required by U.S. federal safety
standards (this includes any garage
door opener model manufactured
before April 1, 1982). A garage
door which cannot detect an
object, signaling the door to stop
and reverse, does not meet current
U.S. federal safety standards. For
more information on this matter,
call toll-free: 1–800–355–3515.
Programming
1. Prepare for programming the
HomeLinkt Universal Transmitter
by erasing all three of the factory
default channels by holding down
the two outside controls until the
red light begins to flash (20-30
seconds). Release both controls.
2. Hold the end of your hand-held
transmitter against the HomeLinkt
Universal Transmitter (located on
your visor) while keeping the red
light in view.
43
3. Using both hands, press the
hand-held transmitter control and
the desired channel control on the
HomeLinkt Universal Transmitter.
Do not release the controls until
step 4 has been completed.
4. Hold down both controls until
the red light begins to flash slowly
and then rapidly. Rapid flashing
indicates successful programming
of the new frequency signal.
5. Follow steps 2 through 4 to
program the remaining two
channels.
If you do not successfully program
the HomeLinkt Universal
Transmitter after repeated
attempts, refer to Training a
rolling code
which follows or call
toll-free customer assistance:
1–800–355–3515.
44
Operating the HomeLinkT
Once programmed, the HomeLinkt
Universal Transmitter can be used
in place of hand-held transmitters.
appropriate channel control on the
transmitter (the red light will
illuminate, indicating the signal is
being transmitted).
3. Press the programmed
HomeLinkt control in the vehicle
until the training light on the
garage door receiver turns solid
HomeLinkt control and repress to
turn off the training light.
4. Press the HomeLinkt control
again. If the garage door activates,
Transmitter has been trained to
the receiver.
Erasing channels
To erase all three programmed
channels:
1. Hold down the two outside
controls until the red light begins
to flash.
2. Release both controls.
Channels cannot be erased
individually, but can be
reprogrammed. Refer to
Programming for instructions.
Oct 21, 2008 | 1999 Lincoln Town Car
Computers & Internet Logo
443 people viewed this question
David Payne
David Payne
