Question about Dewalt 13 in Planer
I have a Dewalt 735 110 volt thicknesser which had the plug cut off! three wires - black, white and green. Which is active and which colour goes to the big pin?
  • robertandker Mar 23, 2011
    Thanks - problem solved!
  • 2,510 Answers
The white wire is the Neutral return wire and goes on the right hand side of the plug viewed from the pin side with the round earth at the bottom. The black is the live wire and is the other pin next to the neutral one, and the big round one at the bottom is the earth wire and is green.
Posted on Mar 23, 2011
  • 6,674 Answers
Green to ground ( center pin-"U" shape ) Black (hot) to smaller of spades, (copper.) White ( neutral) to larger of 2 spades. (silver)
  • Mike Butler
    Mike Butler Mar 23, 2011
    Green (ground) may be round as well.
Had to put dfferent plug what is the order the wires go on dryerto plug
White goes to middle post. Red goes to post with red wire and black to black. Green goes to green ground screw around opening for terminal block.
Nov 12, 2017 | Dryers
Where can I find the wirring diagram for 12 volt reversing camera
i think it goes
Polaris Red-Camera Yellow Polaris Black-Camera Black Polaris white-Camera white and polaris Green-camera bare hope this helps
Nov 24, 2014 | Car Audio & Video
How do I wire the plug to a Lotos plasma cutter for 220 volt ?
There are three wires on the machine, RED BLUE and YELLOW GREEN. In a standard US 220 VAC connection there is red, black and white. RED is connected to red, BLUE is connected to black and YELLOW GREEN is connected to white.
Sep 12, 2014 | Lotos LT5000D 50-Amp Plasma Cutter
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
Power cord was ran over by lawn mower and cut into a black and white wire from inside was unplugged at this time I need to know where does white and black wire plug back in
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
Aug 22, 2010 | Intex '10 Saltwater System Pool...
How do I fix an electrical plug on my vacuum
cut it off. go to a hardware store and get a three prong plug which you can install onto the wire.
when you prepare the wire you will see a black wire, a white, and a green.
black goes to the brass screw, white goes to the dull screw and green goes to the green ground screw.
Sep 16, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Im installing a new sterio in a 95 mustang ----i need a colour code dia. of the wires on the old factory sterio. Which wire goes where?
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Jun 17, 2009 | 1995 Ford Mustang
GE Easycare Wiring Specs
Not sure what part of the machine component you are referring to but generally the colours mean the following using 240 volts:
Red=Active
Black=Neutral
Green or Green/Yellow=Earth (ground)
White=Switched Active (Become active via a switching component).
I think you should clarify what your attempting to wire up before proceeding.
Aug 20, 2008 | GE Profile Harmony DPGT750EC Electric...
Dewalt 13 in Planer Logo
64 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
ka4iup
ka4iup
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
