Question about Vtech DECT 6.0 Digital Cordless Phone
I got a vtech chordless phone and 1 of them will not connect,how do i reset the phone
  • 255 Answers
For this,check for a reset button below the main unit or the handset. This would reset your button,refer to your user manual on how to set it up.
Posted on Mar 23, 2011
Chordless phone went through washing machine
I'm afriad that phones and water and the stuff put in washing machines plus the kocking about in the spin cycle will have caused lots of damage. If it was under gurantee I can't see them covering it due to the nature of the accident. Fixing it would cost as much as a new phone. It's only good for the bin!
Jan 25, 2015 | VTech Communications CareLine Home Safety...
The corded phone fell and now the number 1 does not work
Possible that
1.There is a break in the circuit board
2. Possible that the number 1 button has jumped out of the pad.
3. the pad contacts are off the track.
Remove the board and reset after checking the above sections. If there is crack resolder and bridge the connections.
Sep 18, 2010 | Vtech Lands Phones
I lost directions and would like to block calls on my chordless vtech
You can download the manual from the manufacturer's web site at
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=314062
Aug 20, 2010 | Vtech CS5121 Cordless Phone
One 6041 handset will not connect, while the second handset does.
Unplug the entire phone set system from both electrical power and wall jack for approx 2-3 minutes and replug.
It's a reset measure that allows the entire system to reset / reboot as well as stops any and all line feed memory from the live phone line to hold the fault.
Such can be somewhat common when sharing the line with a DSL connection or wireless router is in use.
Jul 27, 2009 | Vtech Cordless 6041 Phone
CHORDLESS PHONE PROBLEMS
Your ID info is provided by your telephone carrier. If your information isn't being provided, check with your provider to find out why.
Jun 26, 2009 | Lands Phones
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Ringer off
http://www.vtechphones.com/vtechui/support/manual_list.cfm
Mar 10, 2008 | Memorex 2.4GHz Phone (MPH7828)
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Vtech DECT 6.0 Digital Cordless Phone Logo
434 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
