Question about Hoover HTC243 Top Load Washer
How to remove lint from Hoover 500md - Hoover HTC243 Top Load Washer
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
Can i use suspension rods from a hoover 500md and put them in a Simpson 750 WMD 68
as both machines are made by electrolux factory, it is a possibility
check the overhaul lengths and the method of fitment
Jan 14, 2018 | Miscellaneous
Hoover tumble dryer vhv 380 filter care light constantly on even thou there all spotless .....please help
Please vacuum the lint filter housing and check the outside vent on your house for any lint build-up.
Oct 16, 2015 | Hoover Dryers
Hoover windtunnel air - stopped working
I just has the same problem, there is a clog in the intake hose. I removed the hose and used a cloth dryer lint brush to push out the clog.
Aug 05, 2012 | Hoover UH70400 - Windtunnel UH70400...
I can't find the filter location for Hoover 202M 5.5kg washing machine. Can you pls help.
The filter is in the agitator. Remove the agitator cap, and you will find it down there. The filter is pretty much useless. Even though you might get some lint in the filter, if it wasn't there the lint would go down the drain. This machine has a neutral drain feature where the lint gets pumped out with the rinse water before the bowl turns, so preventing the lint from being stirred up nd put through the clothes. Cheerts Tony.
Sep 07, 2010 | Washing Machines
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
How do I remove the agitator in a Hoover 500MD machine?
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Aug 25, 2009 | Washing Machines
I can't figure out how to get all the lint/junk out of my bagless hoover mach 4.
After you remove the cup, remove the foam or hepa filter. Reach up inside, where the cup & filter go and there will probably be a piece with what looks like fins on it. Unlatch this. It is a prefilter, to catch the big stuff that gets past the cup.
Jan 04, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover HTC243 Top Load Washer Logo
320 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
