Question about Canon CanoScan LiDE 600F Flatbed Scanner
How can Ifind and use scan gear application in Canon scan LIDE 600F with Widows 7 64bit. Thanks in advance, DIMITRIS
jackboy
  • 2985 Answers
SOURCE: Canoscan LIDE 600F negative scanning
Colour Negative.?
Have you the software set correctly.?
Posted on Dec 26, 2007
SOURCE: Canoscan Lide 25
http://software.canon-europe.com/software/0027456.asp
The program you can download on this page allowes your computer to communicate with your scanner.
Works for me
VLAD
Posted on May 12, 2008
SOURCE: LiDE 600DF - Unable to scan
I think I might have solved my own problem, at least for the time being. If my theory is correct, then it might be a permanent solution.
I had been goint through the "CanoScan Toolbox 5" configuration line by line to see if anything would suggest a solution when I noticed that the "Folder for where temporary files are stored" had an enormously long path of C:\Documents and Settings\username\Application Data\Canon\TB50\...... By the time the temporary filename is added to the end, it may have exceeded the permissible length the system can handle. So I changed it to C:\Temp and it all started to work for me.
Worth a try for my fellow sufferers.
Trying4
Posted on Aug 23, 2008
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Posted on Sep 30, 2008
SOURCE: I CAN'T TURN ON MY SCANNER
Have you unlocked it with the button on the back?
Thre is no ON button. You just choose which function you want and press the button for it, or bring up the CanoScan toolbox on your screen and select it from there.
Posted on Dec 03, 2008
Gray line in the middle of scan in Canon Lide 600F
Clean the ccd/ scanner lamp with clean cotton, if problem persists then check the flex cable and clean its tracks..
Jan 07, 2016 | Canon CanoScan LiDE 600F Flatbed Scanner
Canoscan Lide 600F I can't scan bacause I keep getting a message about a target disc????
target disc means hard drive or other disc that the file temporary loads to. its either full or most like write protected. right click on the scanner in control panel or the scanners. select "where" to save to in the popup menus
Oct 09, 2010 | Canon CanoScan LiDE 600F Flatbed Scanner
Needs canoscan drivers
Drivers are specific to the operating system (ie drivers for Windows XP may or may not work with Vista). Click on the link below and you will be navigated to the Canon driver download page. Choose your operating system (OS) from the drop-down menu, your preferred language and you will be ready to download the drivers.
CanoScan LiDE 600F
Oct 05, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Is there a manual that shows how to scan slides
Here is the support site for your scanner:
Canon LiDE 600F Support
Under the Drivers & Downloads there are a couple manuals. The Quick Start Guide, which is a PDF file and the On Screen manual which is an exe file. The PDF will open right up. The other you will need to download the file to your desktop and when the download completes you need to run (double-click) the file to install it.
Note: This scanner does not support scanning of Mounted slides. (See Footnote #5 on Page 9 of the Quick Start Guide.)
You may be able to unmount the slides carefully and follow the instructions for scanning film. You might try that on a less desirable slide before unmounting them all. Just a suggestion.
Thanks for using Fixya.
Sep 29, 2009 | Canon LiDE 600F Led Printer
Dec 02, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Failure to open OCR documents scanned into Microsoft Word in a readable format
Have you installed OmniPage? What OS are you using? Which scanner did you have previously? Are you able to OCR a document through OmniPage?
Jul 26, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Hi Peter
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Colour Negative.?
Nov 27, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Light stripe on scans
Possible causes, CCD failure, smudges or marks that can only be picked up by the CCD if the underside of the scanner glass is dirty. Uninstalling/reinstalling your scanner driver will eliminate if its software related or not. From the looks of it, could be with the CCD if the lines are in the same area with every scan attempted.
Aug 18, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan  LiDE 600F Flatbed Scanner Logo
old marine
old marine
