Question about Sentry Fire Safe - Safe - DS0200
We have a sentry safe T5330 Model No. 922252 which looks like your DS0200. We cannot open it or have the combination? Battery not working How do I get into it? Thanks.
SOURCE: sentry safe V530
Send a notarized letter stating you are the owner of the safe with the serial number and a $8.00 money order to
Sentry Group
Attn: Dept 200,882 Linden Ave
Rochester N.Y. 14625-2784
Posted on Oct 23, 2007
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
SOURCE: Sentry Model 1610 Won't Open
just keep trying and it will open. i had to try like 20 times the other day and it finally opened. good luck because these safe's are junk !
Posted on Nov 09, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Posted on Aug 09, 2010
Repair my sentry safe
A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. But only a small supply in stock.
Jun 08, 2012 | Sentry Fire Safe - Safe - DS0200
I have a problem opening the safe. i need instructions on how to open safe.
Are you sure that you are turning the dial in the right direction? Please see the following link for how to open up your safe and which way to turn your dial : http://www.sentrysafeshop.com//kb_results.asp?ID=15
Dec 09, 2010 | Sentry Fire Safe - Safe - DS0200
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
My safe wont open,.
Got dynamite? Just kidding. have you tried to close it and lock the handle all the way in the up position. and then try to open it up again.
Good luck
Nov 18, 2009 | Sentry Fire Safe - Safe - DS0200
Cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Nov 03, 2009 | Sentry Fireproof Safe
I have a sentry safe with a key and combination lock i have misplaced my combination now what
Sentry Safe lost combination. First, find your sentry floor safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Jul 13, 2009 | Sentry Fireproof Safe
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Nov 16, 2008 | Sentry Fireproof Safe
Sentry safe V530
may have been 8 bucks , but it's 12 bucks now.
check out www.sentrysafe.com ,
look on right side menu for "keys" and/or "combination" .
Aug 28, 2007 | Sentry Fireproof Safe
Sentry Fire Safe -  Safe - DS0200 Logo
314 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
