Question about EXPOBAR Office Control Espresso Machine
The steamer on my stafco 2 group coffee machine is just letting out water and not steam, it,s making coffee ok so is hot enough so don,t know what,s wrong, can you help. thanks
2 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: safety valve cn10 keeps activating about 10
Try this open the steam wand and leave on when turning the machine on, when valve stats hissing with steam close. If that works then the vent valve needs to be replaced, If it blows out hot steam from valve then the pressure stat is not operating properly.
Posted on Jul 02, 2010
Delonghi stiromeglio master steamer iron , why no steam to the iron?
If you have been using tap water it may be plugged up with minerals.
Sep 13, 2014 | Coffee Makers & Espresso Machines
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Hi, We have just bought a DeLonghi Caffe Treviso. We are not able to get any coffee/liquid to drip out of the filter holder. The problem seems to occur when we are trying to preheat the machine, for...
Sounds like you need to prime the water pump. Remove the filter holder, open the steam knob and then press the coffee delivery switch. Wait for water to flow consistently from the steamer and then close the steam knob. Water should then be forced to flow through the goup head (coffee head). If you cannot get water to flow from steamer then the pump may have already been damaged or it may have been faulty from the start. If water will flow through steamer but not for the coffee, then the group head is blocked. Good luck hope this helps and remember that all machines should be primed like this before use.
Dec 15, 2010 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Safety valve cn10 keeps activating about 10 seconds after switch on. any ideas anyone. stafco markus 2 group semi auto
Jun 22, 2010 | EXPOBAR Office Control Espresso Machine
ECM Giotto releases steam instead of water from the coffee group
Check the shower screen and diffuser in the head, they might be blocked, if not, check the metering jet at the top of the head(large nut) CAREFUL, make sure machine is off and cool before removing, use a paperclip or pipe cleaner to clear blockage. If not blocked then you will have to check the brew solenoid.
Mar 02, 2010 | ECM Giotto Espresso Machine
When trying to steam milk, very hot water comes out of the steamer arm and curdles the milks. Additionally no hot water comes out of the opening for the coffee, so no espresso is made. This started...
It seems that your problem is the one mention second that no water come out for coffee. So every time you try to make coffee the boiler is overflow and you have more water from steam tap.
So you have to clean the coffee shower on coffee group head since this might be blocked by dry coffee. Also the coffee solenoid valve could be also blocked from dry coffee and it can be removed and cleaned with a wire brush. It can be also be damage and most posible the solenoid coil burn out so you might need a new solenoid. So I beleive if you solve the coffee group blocked problem then you might have solve also the steam problem,
Good Luck
Remeber to vote for this answer.
Feb 23, 2010 | Krups Cappuccino/Espresso Maker -...
Don't know how to work the steamer.
I have the same Conair Cuisine Ultra expresso maker as you; its an old one. Make sure the coffee grind is in the spoon/filter cup and as the water heats it will brew the expresso. Simply twist the the knob at the top of the silver steam valve stem will let out hot steam for you to frosh the milk.
Nov 24, 2008 | Coffee Makers & Espresso Machines
Cannot express the coffee into the cups
Solution nr one cold be the machine ran out of water and the circuit need to be filled up again.
This is the procedure to do that
Fill up your water tank
Open the steam knob na push the coffe button...in that way the water will be forced to go to the steamer.If you have water in the steamer like you asking for hot water....go to the next step
Close the steam knob and at that point you will hear a different noise and the watewr should be able to go direct into the boiler and start dripping like it was before.
if you don`t have hot water coming oput from the steamer....the problem is before the boiler and could be a clog on the silicon tube or the water pump is loosing friction..
Pls don`t forget to rate your experience
Fabio
Apr 26, 2008 | Saeco VIA Venezia
Saeco Magic De Luxe - hot water / steam but no coffe through the brew group
our taking about the plastic piece with 2 seal on it if it that its very easy to change that thing is screwed in the boiler try to unscrew the piece if you cant you gonna have to remove the boiler i know does machine good let me know thanks for using fixya pierre
Feb 13, 2008 | Saeco Magic De Luxe Espresso Machine
EXPOBAR Office Control Espresso Machine Logo
44 people viewed this question
Top EXPOBAR Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Kolbrun...
Are you an EXPOBAR Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
