How to identify a defective rectifier diode - Computers & Internet
Before you throw out that 'defective' diode, consider that your multitester may not be strong enough to truly detect current flow. Try hooking up a 9 volt battery in series with the diode (on your test bench). If the diode is good, your multimeter will detect higher voltage one way through the diode than the other way when probes are reversed. This might save you some anguish when you test a rectifier diode from a microwave, for example.
Posted on Oct 07, 2014
  • Computers & ... Master
  • 32,281 Answers
You can check a rectifier diode using a multimeter - Set the meter to the lowest ohm range and place the probes at each end of the diode. Take a reading then reverse the probes at the ends of the diode and take a reading again.
A good diode will show a low reading when the diode conducts and a high reading when it does not conduct when the probes are swapped around.
A bad diode will show a low reading (short circuit) when it the measurements are taken both ways.
A bad diode will show a high reading (open circuit) when it the measurements are taken both ways.
This is may not be accurate if the diodes are still soldered to the circuit board, you may need to unsolder one leg of the diode free of the circuit board and then carry out the measurements to get a true reading on the diodes.
Posted on Mar 23, 2011
SOURCE:
My engine is draining batteries. It starts and runs fine at first then struggles to start in future uses and will not restart if I stop.
The following is from the Briggs and Statton FAQ website:
Battery Not Charging
  • Engine RPM too low
  • Inline fuse "blown" (if equipped)
  • Defective battery
  • Loose, pinched, or corroded battery ground leads
  • Loose, pinched, or corroded battery charge leads
  • Open, shorted, or grounded wires between output connector and battery
  • Defective diode (open or shorted)
  • Defective or improperly grounded regulator-rectifier
  • Diode installed incorrectly (reversed)
  • Damaged battery (shorted battery cells)
  • Excessive current draw from accessories
  • Damaged alternator magnets
  • Defective stator
May 04, 2015 | Briggs AND Stratton Intek Briggs &...
If the rectifier is defective would it chip tht circuit bbaker to the power source
Yes almost certainly if it (the rectifier) has gone short circuit, but you should be able to test the rectifier with a test meter; disconnect mains and rectifier, forward and reverse resistance should be low and very high for each diode leg in each direction of test leads (4 diodes if it has 4 wires)
test each leg both ways, or get testmeter with diode test
Jul 14, 2014 | Black & Decker 19" Electric Lawnhog...
Defective Magnatron
This is probably because there are some defective capactors in the oven. If you replace the magnatron without replacing the caps your going to be blowing it again. Be vert careful those caps store high voltages and must be discharged before you do anything. It could also be a defective rectifier bridge even if only one diode is bad
Good luck
Mar 10, 2014 | GE JEB1095 Convection/Microwave Oven
Computer box
You supplied proprietary part identifiers for your unknown brand computer monitor. Without more specific details there is not much we can do to help
Jun 11, 2013 | Computers & Internet
What is rectifier
A rectifier for a alternator or charging system is a set of diodes. A diode is a one way "valve" for electricity allowing flow in only one direction. Typically a rectifier has 6 diodes, 3 positive and 3 negative.
When diodes fail, electricity leaks to ground and systems discharge.
Feb 13, 2011 | Computers & Internet
Battery light stays on engine running
have batter and altneater checked or belt if broke
Jan 23, 2010 | 2004 Ford Focus
My subwoofer IC got burned because i accidentally plug it to a 220v power supply, mine is only 110v i want to know the IC# subwoofer.
Most likely what got burnt is the bridge rectifier in the power supply section of the electronic circuit. This usually takes the shape of either a single 4-legged IC, or a group of 4 rectifying diodes connected in a bridge configuration. If you disassemble the unit to which the power cord is attached & trace the circuit starting from the terminals of the power chord, you can easily identify it. You will need to replace the 4-legged IC or the 4 rectifying diodes.
You will also need to replace the fuse, since it is usually likely that it gets burnt if the unit is attached to 220V instead of 110V.
Nov 24, 2009 | Altec Lansing FX4021 Computer Speakers
Bad diode.
It seems that the number provided "CR14710" is the number near the part on the board. Are you sure this is the part number or rather, is it the part's schematic reference? I interpret "CR14710" as Control Rectifier 14710 that can be found on a schematic. I say this because you also said "a badly burned diode" and usually the part number becomes illegible from this.
Dec 11, 2007 | RCA F38310 38" TV
Computers & Internet Logo
637 people viewed this question
Alun Cox
