Question about EPoX EP-8RDA3I Motherboard
I have a problem. MY 8RDA3I motherboard includes, FAN COOL, post-ff and all PROCESSOR warm. Thanks in advance. I am from RUSSIA.
  • 1,381 Answers
Probably the processors fan is defective or the processor grill is filled with dust and dirt . Unscrew the fan
and give it a good clean up . Use a air spray to clean up the processors gril preferably to a vacuum unless you handle with extreme caution .
Check also the general fan .
Dust is the nr 1 ennemy of the pc . Hold the inside spotlessly clean .
Best regards,
fanaudi
Posted on Mar 23, 2011
I need Epox 8RDA3I manual
Note: This was a difficult manual to find. I couldn't find the exact model's user guide but I did find one in the same series. Download it and see if it will work for you.
Follow this link for the Epox 8RDA manual: http://files.aoaforums.com/I1474-8rda%20manual.pdf.html
Click on "Click Here To Download This File from server cluster #3" to download file.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
May 12, 2011 | EPoX EP-8RDA3I Motherboard
Manual EPoX EP-8RDA3I Motherboard
http://www.epox.com/downloads.asp
download here
i hope this helpful
thank you for using fixya
Feb 05, 2011 | EPoX EP-8RDA3I Motherboard
Nx6115 powers on but shuts off after a minute. litteraly shuts off
Hi.
This is caused by the fan and cooling system.
Disassemble your laptop, remove the fan cooler, clean it up, replace the paste on top of your processor, tighten and screw the cooler fan again.
power up your laptop and good luck
Feb 02, 2011 | Compaq nx6115 nx6125 Series FullFeatured...
When I boot computer I have no video, no beeps. Power supply checks good. I have cooling fan, stand by light is on motherboard. It has a segate barracuda 7200.9 160 gig hard drive that is making no noise....
remove the computer covers remove the memory from slot and clean the memory with clean soft clothalso remove the processor fan from the socket clean the surcace of the heatsink and the processor and apply thin layer of heatsink solventand fix the processor fan firmly on the processor socket
Jan 14, 2011 | AOpen AX3S (91.87A10.001) Motherboard
HI ! I bought a new AMD phenom quad-core 9750 2.40ghz processor and Gigabyte motherboard. I m unable to install Windows and the system automatically shuts down every 20 min and sometimes runs for more...
This processor need better cooling system as it is powerful it need more power so I suggest you to upgrade your Power Supply and buy more efficient processor fan cooler. Also you should check if processor is properly installed on motherboard and there should be some special thermal grease between processor and motherboard (http://en.wikipedia.org/wiki/Thermal_grease) for better thermal conductivity
Oct 25, 2010 | AMD Phenom X4 9750 Quad Core Processor...
EP-8RDA3I bios error problem with flashing bios info on screen BIOS ROM check sum error
Retry downloading you bios update and use another removable media (floppy or USB) with suficient free space.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | EPoX EP-8RDA3I Motherboard
The right type of motherboard for compaq presario 2200 pc
Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371793-001 System board (motherboard) - De-featured (DEF) for Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory (dynamic) - Does not include IEEE 1394 (Firewire) or TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original 371794-001 System board (motherboard) - Full-featured (FF) with support for Intel Pentium M (Dothan and Trailing Bin) and Intel Celeron M (Banias) processors, 32MB or 64MB shared system memory - With IEEE 1394 (Firewire) and TV-out (S-video) RoHS: Original
Mar 02, 2010 | HP Compaq Presario 2200 Notebook
Thise is Fred. A few days ago i assembled a Pentium 4
Some fans are controlled by temperature-sensitive sensors.
So, if the motherboard is "cool enough", the speed of the fan will be reduced to "zero".
Sometimes, a motherboard can enter "standby" mode.
This mode consumes only a small amount of power;
and the fan will be stopped, because the cooling it provides is not needed.
Dec 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Ventilator of the microprocessor
Most modern motherboards include temperature sensors that can speed up or slow down the CPU fan depending on how hot the processor is. If its noisier than it was originally it could be: -inefficient cooling caused by dust accumulating in the heatsink under the fan. -could be heat buildup in the case itself causing the processor to run hot. -could just be noisier because the bearing in the CPU fan is wearing out. -Make sure the CPU fan power cable is plugged into the proper socket. If it?s not the motherboard cannot control the speed. Let us know if you have any other questions.
Jul 09, 2007 | Thermaltake Intel LGA775 1/2U Solution...
EPoX EP-8RDA3I Motherboard Logo
89 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
