Royal Davinci DV3 Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My royal is just showing \r\nCALIBRATION\r\nDo not Quit before tap=irs the intersection of the crossed lines top-left and then the bottom-right
Anonymous
Level 3:
  • Master 314 Answers
  • Posted on Mar 23, 2011
Anonymous
Master
Level 3:
Answers
314
Questions
Helped
40041
Points
1024
Hi balwinder_jo,
Try restarting the device. if the problem is still showing try taking the battery out and leave it off for a few minutes.
other than that i am not sure for any other solutions.
Work centre 5775 touch control do not work properly because of wrong calliberation
Enter the UI Diagnostic Tests menu by simultaneously pressing the Phone, #, and * buttons.
Use the number key pad on the Control Panel to select Diagnostic Test number for Touch Panel Calibration
A grid will appear on the touch screen with intersecting lines.
Use a pencil to tap the center of the + in the top left. The + will move around, each time it does use the pencil to touch the center of the +
After you touch the center of the + for the bottom right corner, the calibration should be complete
Exit out of the UI Diagnostics by pressing 0 for Exit
Nov 11, 2017 • Cell Phones
Abs hydraulic unit chevy truck
The ABS unit should have the connection IDs embossed into the casting at every line connection.You are going to HAVE TO determine every connection line going to every component to make this work.
Screen not aligned
Ref. HP ipaq hx4700: "Align screen" after hard reset or battery loss. I know others have had trouble getting past the "align screen" setup; I saw a suggestion somewhere that said the points were registered incorrectly (maybe in some, but not all of this model?); and they had to tap at locations other than the center of the cross symbol. I tried a variety of combinations, and found that if I tap ABOVE the center (but still on the vertical centerline) for the middle, top left and top right locations; and tap BELOW the center (but still on the vertical centerline) for the bottom left and bottom right...it worked. That brought me to the "Stylus" setup screen...which I also became "stuck" on. So far, I haven't found a solution to THAT issue yet. Gee, why can't they make these things simpler?
Align screen problem
Can't boot from usb drive or usb cdrom Tendai
Try to get into the BIOS - when computer first starts a message bottom left will show.... press F1 to enter Set up it migght show esc F1 or F2 or something like that . Whatever it is - Tap that key AS SOON AS YOU SEE THE MESSAGE. - you may have to have one or two attempts you may be lucky and get it first time.
In BIOS go to the BOOT screen - (usually right arrow key to get there) Usually the top item is "Boot order" highlight it and tap the Enter key
Hilight the CDROM line and follow help file on the right ( maybe F5/F6 to move up/down) move cd to top line... this is the 'boot from' line
Note - to boot from USB stick - it MUST be in place BEFORE you go into BIOS - hilight the USB Stick and move that up to the top.
Tap the F10 key then Enter to save and exit BIOS.
Tap the enter key when "hit any key to boot from CD" appears
Done.
Cheers.
My imate jama101 is lock it say tap but how many weeks already its still not align how will i stop it and open it,,pls help
most probably it would be showing a + sign in the center just keep on tapping in the center of + sign where ever it appears. At first it appears at the center then at the top left, then at the top right, then at bottom right and finally at left bottom, just keep on tapping at the center of + sign, now continue with the setup
How can i use cross street or intersection
Tap on: main screen. Tap on: Navigate to. Tap on: Address. Tap on:: Crossing or intersection. Tap to select city. Enter the street name. Enter the crossing street name. Tap done.
3helpful
How to set up restrictions through line restriction filters
It's best if you use the "reply to post" window below the solution box so you can continue the same thread with the same person.
To set up the restriction filters we'll need to get into programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key (bottom right arrow).
The display should now LINES.
Press the show key (top right arrow)
The display should now ask for a line number.
Enter line number you want to change the line filter on. ex. 002 = line 2
The display should say Trunk/Line data
Press the next key 2 times (bottom right arrow) .
The display should say Restrictions.
The display should say Restriction Filters
Enter in the restriction filter 25
The display should say No Restrictions and the ADD soft key should appear on the lower right soft key
Press the add soft key and in the restrictions you want on the line.ex. 011any will bolck int'l dialing but not long distance. 0any and 1any will block long distance, operator assisted calls, and int'l dialing
You can also add overrides by pressing the show key (top right arrow) then the next key (bottom right arrow) .The display should say no over rides and the add soft key should appear on the right soft key.
When finished with the filter press the heading key(top left arrow)
Press the next key (bottom right arrow) .
The display should say Line restrictions
The display should say Normal:none
Press the change key and enter 25.
Press the heading key (top left arrow) til the display says Lines.
Press the back key (bottom left arrow)
The display should say Terminals&Sets
Enter in the extension number of the person you want to allow free use of the line.
Press the next key 4 times(bottom right key)
Press the next key 2 times(bottom right arrow)
The display should say Line/Set restrictions
The display should ask for a line number.
Enter in the number of the line that was restricted.
The display should say Normal: none
Change the filter to 00 (no restrictions)
That bypasses this extension from line filter 25
Press the release key when finished
1helpful
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
3helpful
2answers
Wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Top Royal Computers & Internet Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Royal Computer and Internet Expert? Answer questions, earn points and help others
