Question about Hotpoint Dryers
Hotpoint Ultima Condenser Dryer TDC62 - No Heat
    Sergeant:
    Champion:
  • 422 Answers
That trouble is cause by an heater that is already open- no connectivity. Also the wire connected to it.
I hope I answer your problem.
Posted on Mar 23, 2011
Hotpoint ultima tumble dryer
sounds like its blocked with fluff somewhere and your element could be wet take off the back and check your element and if water around it you need to compleatly clean out your filters and down where the condenser is then leave it for a day or two to compleatly dry the element
Apr 07, 2014 | Hotpoint 1701746 Ultima Tc71n Condenser...
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
Hotpoint ultima condenser dryer TC71 is running cold
Thermostats rarely go. You could have a bad heater or even a voltage problem. Even if the dryer runs, the voltage can still be wrong, it only needs 110 volts to start the motor but must have 220 to have heat.
Apr 06, 2009 | Dryers
Hotpoint Ultima Condenser Dryer - where is the reservoir?
under the door, you need to take the small panel off and its there.
Mar 03, 2009 | Hotpoint Dryers
Hotpoint TDC62 condenser dryer does not heat up Hotpoint TDC62 drying light does not come on. It flashes briefly when you press the start button but then goes straight off. Why? If you tap the machine the...
Most likely, the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. Mine had the same problem and changing it sorted it. I also replaced all the four small electrolyte capacitors on the circuit board (which you don't have to replace - I am a bit fussy with capacitors).
Your thermostats and heating elements are good (don't change these).
Jan 17, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC62 condenser dryer does not heat up My hotpoint tdc62 does not heat up. I had it for approx. 5 yrs, have changed the thermostats(years) before,but have come up with a new (recent)problem. when...
I think the problem still lies with the thermal switches, they have a tendancy to corrode where the spade connector attaches to the body (see pic)
Mar 11, 2008 | Dryers
your thermostats have most likely gone they are situated at the back of the machine on top of the heater
Feb 09, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Ultima Condensor Dryer
on the back of your dryer you have a heater behind the protruding panel... Either you heater element has gone, but most like the thermal cut outs have blown...these are located in the same area..they are small and round looking and are connected to them are wires either side. Anyways check the conitunity of the termal cut outs using a tester if no continuity then they are no good... hope it helps...
Nov 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
310 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
