Question about LaCie Computers & Internet
No monitor resolution choices in mac 9.2
I am running 9.2 on a Mac G4 but there is a problem with the Lacie monitor resolution...I can't change it from 260x480.
Help.
  • 1 more comment
  • crstudio Aug 04, 2008
    I am running a MAC. There is no such thing as a right click.
    Under my monitor resolution settings the only listing is 640 x 480. All the other options are gone. How do I get them back?
    I have tried reinstalling my OS and also Disc First Aid...nothing seems to help.
  • crstudio Aug 05, 2008
    My Mac came with a 16" Sony Trinitron Multiscan G220 monitor so I switched it back to that. The monitor resolution was OK with the Sony for quite awhile...but now it does not give me any resolution options to chose from. What is the problem???
  • 6,487 Answers
Try updating the software for your video card and that should do the trick.. By the way was this working fine before changing the resolution?
Posted on Aug 04, 2008
    Genius:
  • 1,269 Answers
Your video card is incompatible with your your LCD monitor. You might need to upgrade your video card. To see the list of compatible video cards with your Mac model, pls go to this link:
http://support.apple.com/kb/HT1825
for adapter model, go here:
http://docs.info.apple.com/article.html?artnum=33001
hope that helps
Posted on Aug 03, 2008
  • 1,879 Answers
It is not your monitor, more the graphics card. Try reinstalling the OS, or try updating from the apple menu.
Run Disk Utility and Repair Permissions. Then do a Repair Disk. Disk Utility should be in your Apps Folder - under Utilities.
    Guru:
  • 1,894 Answers
You can change the resolution easily
in your desktop right click and go to properties
there go to last option settings.
there you can change the resolution
    Genius:
  • 1,847 Answers
That is video driver issue
  • Legin Varghese
    Legin Varghese Aug 03, 2008
    If you have the video driver cd install it that will fix the isue.
I'm trying to hook up my Westinghouse L2410NM 24 inch monitor to my MacBook Pro. I'm using the DVI adaptor for my mac to connect to the monitor via an DVI-HDMI cable. My mac seems to detect the L2410NM,...
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
Nov 13, 2010 | Apple MacBook Pro Notebook
PowerBook G4 15" 1.25 GHz - The native resolution (1280x854) does not show up in my monitor preferences. The highest listed is 1152x768. I reset the PRAM and NVRAM but still no change. Any ideas? Here is...
According to the specs you listed here, max resolution for your LCD panel is 1152 x 768. If you plug into an external monitor you should be able to get 1280 x 854,
Nov 30, 2009 | Apple PowerBook G4 Mac Notebook
My monitor goes black with a horz white line across the center. It is a Lacie on a g4 mac . It is about 6 years. old.
The lcd is bad usually the lines start very small and rapidly over time become about an inch or so thick.
Oct 07, 2009 | Computers & Internet
Monitor resolution setting
I would check for new drivers for the video card. They usually have higher resolution abilities for these fancy wide screen monitors.
Jul 22, 2009 | Samsung 943BWX Monitor
Display problem Mac Mini G4 10.5.7
Try updating to 10.5.8 which was recently released, I saw mention of an HDMI display bug that this may fix.
May 19, 2009 | Apple Mac mini G4 Desktop
Resolution
Have you tried updating your graphics card? Go to ATI's website and try updating your video card and hopefully that solves your problem. Go to amd.com and go to ATI tab to update your driver. I forgot ATI is under AMD's umbrella
Dec 06, 2008 | ViewSonic VA1930WM LCD Monitor
My LG W2234S BN monitor will not come out of power safe mode when plugged into my G4 Mac. It's fine with my pc. I have reduced the resolution on the mac, and changed the refresh rate to 60Hz, but it still...
It could be that one of the computers supports analog and the other supports digital. You should be able to switch between the two input methods directly from your monitor via the buttons in the front.
Hope this helps.
Nov 27, 2008 | Computers & Internet
Mac Mini G4 Flickering Screen at Start Up
Did you check the wires?  Sometimes if you pull one loose it flickers.
Aug 13, 2008 | Apple Mac mini G4 Desktop
EMac screen resolution size is only one choice 800x600
1st start it in safe mode.install video driver from motherboard support cd.then start it in normal mode.then you may change your monitor resolution.
Feb 08, 2008 | Apple eMac G4 M9425LL/A Desktop
Computers & Internet Logo
124 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
