Question about Electrolux EW1200i Front Load Washer / Dryer
Why do we hear some noises when spinning? Yesterday, when I turned on the drier, I could hear some sound as if some boxes are inside it. Later , I took the clothes out and tried to wash few clothes, however, immediately after the clothes were soaked, I heard the noise again and it did'nt turn. What would be the problem?
    Brigadier General:
  • 6,277 Answers
Try this first just in case but note the last comment!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 23, 2011
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
Jun 17, 2013 | Creda S202pw Debonair Spin Dryer Drier 9lb...
Bosch Exxcel Condenser
replace the broken drive belt
May 13, 2013 | Dryers
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
LG -External Hard Disk not working I have an LG HDD HXD2 - 250 GB and yesterday I unplugged without safe to remove . When i tried to reconnect HDD, the blue light is on and the hard disk make sound...
Hello
Welcome to Fixya!
Firstly we will need to establish is the hard drive spindle is actually spinning up. Can you hear it spinning up?
Does the hard drive make a clicking sound?
Let me know any feedback in regards to the above.
If you do hear a clicking noise, it is not good news.
Let me know by means of a comment.
Kind regards
Lock123
Oct 10, 2011 | Computers & Internet
The washing machine is working alright but when its spinning, theres a noise that sounds like its something broken inside... But u cant hear the noise when its on fast spin.
Can be front the drive at the bottom of the washer. I assume this has a high speed spinning and so there is a gear box which can be having less lubrication. So make sure that the motor drive section of the drum shaft assembly is well lubricated so that the noise at high speed reduces.
if you can do a mechanical job , it will be good to remove and reset with good lubrication and maybe replacement of the bearings.
Jan 20, 2011 | LG WD-16115FD Front Load Washer
Fischer & Paykel Excellence 6.5 1999 model Neclace has gone through wash and drain holes. Making terrible grinding noise. need instructions how to take off cover to find neclace.
Hi just read your posting.Now try this.Select a spin cycle and push the start button.Do you hear the noise straight away after the button is pushed or do you hear the noise later when the machine is starting to turn the bowl?The reason I ask you this is because as soon as you push the start button the drain pump will activate and then a couple of minutes later the bowl will start to turn.So if the noise starts straight away then the necklace is in your pump and if the noise starts later it is stuck to the bowl.Please reply with the additional information and I will guide you throe the removal of the necklace.Looking forward to your reply.
Oct 03, 2010 | Washing Machines
Turn key and wont start 05 2500 silverado
This sounds like a weak battery or corrosion on the battery cable connections. The sound you hear is the relay and not the cylinoid.
Jan 13, 2009 | 2005 Chevrolet Silverado
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Electrolux EW1200i Front Load Washer / Dryer Logo
35 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
