It just says fuser error and I don't know what to do?!
  • 32,281 Answers
Remove the fuser unit from the laser printer, check the two spring contacts are clean and insert it back into the printer. The fuser unit will be very hot if it is working.
If the printer still gives this error message then the fuser unit may be faulty and needs replacing.
Posted on Mar 23, 2011
Getting error 50.90 fuser error, how do I change the fuse?
I checked 5 different printers and couldn't find a 50.90 error code. Since you keep the printer model a secret I haven't got the foggiest idea as to what the error code means, except that it is a fuser error of some kind. And getting back to your question, If I don't know what kind of printer you have I can't tell you how to change the fuse(r).
Sep 01, 2011 | Office Equipment & Supplies
Says "error" and don't know
If the error light is flashing: Check the front door and the fuser door to be sure that they are closed. Also check for any jam including the duplex section. Make sure there is not a sensor flag stuck in the down position. This can indicate memory full, print overrun, size error DX or duplex disabled.
If the error light is not flashing: it can mean there is no paper in tray 1 or the machine may be asking for you to put paper in the multi purpose tray.
Is this the only light that is on?
Jul 06, 2011 | Brother HL2240D Laser Printer
I have problem with my canon copier image ready 5020. error E000004-0000 how do I fix it i'd tried to press 2&8 but its said "Download Mode"
Error E000004 is a fuser related code and is most parts just caused by a paper jam in the fuser area. Before you begin to try and clear the internal flag you must make sure there is no paper or no obstruction stuck in the fuser area. With the power off rotate the fuser model handel to see if any aper or obstruction exsists. Clear it carefully if there is. At any time NEVER USE a knife or sharp object to clear a jam. Common sense I know, but few practice it. Once you clear the paper jam you can see if clearing the flag is the magic you need. If the next stages fail contract a local Canon trained tech to troubleshoot the real source of the error. Clear the error flag do the following steps DO NOT touch any thing else DON'T adjust any numbers. Turn machine on. When main screen apprears press Additional Functions button (*) let go. Press 2 and 8 together let go. Press Additional Funtions button (*) again. Screen should say Service Mode Level 1. Press these screen buttons in the following order. Copier, Functions, Clear, ERR then press OK in lower right corner. Machine will apprear as if nothing has happened but it has. Shut machine off at side. Turn on. Flag is cleared. If code reappears get professional help. This is a fuser code therefore we don't want a fire or anything else happening. Doing this clear you have 30 seconds before macine shuts off. It takes timing. Good Luck.
Jun 28, 2011 | Canon imageRUNNER 5020 Copier
I got 02-000 error on samsung scx-4623f . How can I fix it?
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Samsung SCX4623F Laser All-in-One Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
I getting 50.2 fuser error in hp laserjet printer what i do i don't know can u any one help me
the 50,2 error is a fuser error, and should be serviced by a repair facility. You can try to replace the fuser yourself, but the labor should be pretty cheap compared to the cost of the fuser assembly.
May 06, 2011 | HP LaserJet 5100tn Printer
The printer display says "Open Heat Error". What is this and what causes it?
I'm not real sure but I do know the the fuser area contains heat sensors. If the fuser temp is higher than it should be, you will get over-temp errors.
Get the printer serviced. It very well could be a motherboard failure or a fuser control card.
Don
Feb 18, 2010 | Dell 1600n All-In-One Laser Printer
"922 SERVICE FUSER ERROR"
920, 921, or 922 Fuser Error:
The printer thinks the fuser unit is not heating up to the correct operating temperature. This can be due to a bad fuser lamp or possibly no power getting to the fuser unit. As a customer, the only other thing you can do is to check the connections on both the fuser unit and where it goes into the printer. Make sure neither connection is damaged. If you are a technician working on the printer, you can check the voltage coming off the system board and Low Voltage Power Supply (LVPS) to make sure power is getting to the fuser unit.
Don
Jun 04, 2009 | Lexmark T520 Laser Printer
SYSTEM ERROR
You have a fuser error. Sub code 002 says the temperature dropped significantly after spcified temperatire was reached. I don"t know that particular model, but I would try to find an ERR_CLR somewhere in the service mode.
Aug 31, 2008 | Canon Office Equipment & Supplies
60 people viewed this question
k24674
jasbo
jasbo
