Question about Asrock GE Pro-HT R3 Socket 478 Motherboard (MOTASR04)
Does this motherboard support 2 types of ram? I thought the specs said pc133 and pc2100. please clear this up :)
  • 1,381 Answers
Hello ikyojin
I found this : http://www.asrock.com/mb/overview.asp?Model=GE%20PRO-HT%20R3.0
It says :
Memory - DDR x 2, DDR333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Does this help ?
best regards ,
fanaudi .
Posted on Mar 23, 2011
Testimonial: "Thanks again! Very informative!"
  • 1 more comment
  • fanaudi
    fanaudi Mar 23, 2011
    You're welcome ikyojin
  • ikyojin Mar 23, 2011
    I found the board in question. it seems u retrieved data for the ''3.0'' something or other which doesnt support 2 types. the regular ge pro-ht appears to however. pc2100 and 133
  • fanaudi
    fanaudi Mar 24, 2011
    Thank you very much for the feedback ikyojin . I sincerely apologize for the incorrect information I've given to you . Best regards , fanaudi .
Gege
jfskfnjekfh sefjsefsfmseklfj
efnsfneskfs
\fsekfl
\]sfesml\b
bjsf.f
fksfs
sf
Posted on Jul 20, 2011
1GB PC400 RAM does not work with motherboard A7S266-VM/U2
Hello the home page is here:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=10&m=A7S266-VM%2fU2&os=&hashedid=n%2fa
If any drivers or manual needed select first your windows.
Click on global for download.
Unzip the file and you need a pdf reader (adobe) to read the content.
Here are some specification about you mainboard:
2 x DDR DIMM Sockets
Max.2GB unbuffered PC2100/PC1600 non-ECC SDRAM Memory
2 x SDR DIMM Sockets
Max.2GB unbuffered PC133/PC100 non-ECC SDRAM Memory
(Note: DDR ram and SD ram memory can not be used on A7S266-VM/U2 simultaneously)
This means you can`t use SD RAM together with DDR ram.
The bios could have a setting for this because of the use of 2 different ram types.
Try downloading the manual.
Good luck
Nov 18, 2012 | ASUS A7S266-VM/U2 (A7S266-VM/U2/LAN)...
I need to upgrade my pc ram, pulled the ram and infineon is the manufacturer, they no longer make ram so how do I know what other ram I can put in my motherboard, got number from stickers on the...
Look for labels on the RAM: PC100 or PC133 or DDR266 or DDR333 or DDR400 or PC2100 or PC2700 or PC3200.
Since you cited 'DDR400', you need to purchase 'DDR400' RAM.
Any sales-person in any computer-store can sell you 'DDR400' RAM.
Feb 03, 2011 | Abit NF7-S (V2.0) 400MHz FSB nVidia...
RAM Slot does not recognize more than 512MB ( 184 )
Consider updating your motherboard bios.
http://www.asrock.com/mb/download.asp?Model=K7VT2&o=BIOS
Also make sure that your memory is correct for this system:
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
Jun 26, 2010 | Asrock K7VT2 Motherboard
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mike
Mar 22, 2009 | ASUS P4S533-MX Motherboard
ASUS MOTHERBOARD P4X-X CAN USE ddr 400
pls see ur specs here
http://www.baber.com/motherboards/asus/asus_p4xp-x.htm
ur board only support following RAM specs u cannot use DDR400
Memory
  • 2 x 168-pin SDR DIMM Sockets support max. 2GB PC133/PC100 non-ECC SDRAM memory
  • 2 x 184-pin DDR DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM
pls rate me FIXYA for this help if u like
Mar 13, 2009 | ASUS P4XP-X Motherboard
WINDOWS XP PRO JUST STOPS WORKING
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
ahgqqq-18
Dec 10, 2008 | Intel Motherboard
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Aug 17, 2008 | Computers & Internet
Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
Aug 10, 2008 | Asrock P4I45GV R5 Motherboard
DDR & SDRAM supported?
I suggest you stay within your manual specs.
Your boards memory should not use voltage higher than CL2.5
Below is a link for 1Gb dimm DDR266 PC2100. CL2.5
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80388-1
You can also buy two which would take you to the motherboards MAX memory of 2Gb.
Dec 30, 2007 | Jetway V266B Motherboard
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Asrock GE Pro-HT R3 Socket 478 Motherboard (MOTASR04) Logo
90 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
