Question about Hotpoint Washing Machines
Drum very noisy when in spin - Hotpoint Washing Machines
    Brigadier General:
  • 6,277 Answers
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly- and particularly for the spin cycle ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 23, 2011
Noisy machine AEG Lavamat 35600 Tumble Dryer
moter 1st i would say thx nick
Feb 10, 2008 | Dryers
Noisy spinning
Remove drfive belt if possible, and spin drum by hand, if it is noisy, or feels rough, then main drum bearings have failed, normally a major repair.
Aug 14, 2010 | Washing Machines
Drum bearing noisy on spin
Remove the drum drive belt, and spin the drum by hand.
If it is noisy, or feels rough, then the main drum bearings have failed.
This a major repair.
Hope this helps.
Dec 15, 2009 | Candy Washing Machines
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
