Question about Lenovo IdeaPad Y560 Laptop
I have y560 lenova idea pad with TV tuner.i want BIGTV connect to laptop
    Guru:
  • 868 Answers
Hi krahul17,
I see that you want to connect a BigTV to your Y560 Laptop, I can give you a few details on what you can do to conenct a bBig TV to your Laptop.
- Your Y560 has an HDMI port on it and you can use HDMI to connect an LCD TV to your Y560 Laptop.
- In Windows7 lower right side of your task bar you will see the speaker icon right click on it and it will give you options, see below image.
- Click on Playback Devices
- You should see the sound window inside the window you will see a list of audio devices on your system, you should see your HDMI first on the List with a Picture of an LCD TV next possibly will be your speaker which is set as the Default device the last should be Realtek High Definition audio device.
- Right click on the HDMI and select set as Default Device once set as default device your HDMI video and audio should work but if you connected your Laptop to the TV before you changed this settings you will need to restart you Laptop for the changes to take effect on your system and also make sure that the input for your TV is also set to HDMI to make everytihng work.
- And if you will be going back to using you Laptop only you may need to go back to the sound window to set the speakers as your Default device to make the audio come out from your Laptop Speakers.
I hope that this will be of help regarding your concern, have a nica day.
Posted on Apr 10, 2011
I am trying to connect my lenove laptop tp flatscreen tv i have the cable pluged in to both but nothing
Press the "Input" or "Source" button on the TV remote to select the computer. On the computer, right-click on an empty space on the desktop and select "Screen Resolution". It should show 2 screens. Select the TV, then, from the dropdown menu, select "Duplicate screen".
Sep 26, 2013 | Lenovo 11012137 Ideapad Y560 Laptop System...
I cant seem to get my lenova ideapad to work on flatscreen
Are you using HDMI to connect? In my experience, given a video or audio problem related to home theater, HDMI is responsible 9/10 times. First of all, make sure your TV is set to be displaying the HDMI port your computer is plugged into (can usually changed with the INPUT button on the TV remote). Most laptops have a key that looks like a screen on it. In may be printed in a different color on one of the F1-F12 keys; that just means you need to use the Fn key to activate it. This key opens the Windows display mode chooser dialog. It has some options, all of which I can't recall off the top of my head. I believe they are None, Laptop Only, Projector Only, Mirror, and Extend. Keep in mind that this method is not restricted to projectors (though it would work with them as well), and should also work with your TV. You'll want to choose either Mirror or Extend, depending on your preference. Try both and choose the one that works best for you.
If either I wasn't clear enough or totally missed the mark, just tell me and I'd be happy to fix the issue. ;-)
Sep 26, 2013 | Lenovo IdeaPad Y560 Laptop
Im using lenovo Y560 and wanted to change my font style..how to do it..?
use display setting to make your own setting of fonts and wallpapers etc
Jan 08, 2013 | Lenovo IdeaPad Y560 Laptop
I m unable to instal tv into my ideapad y560 though i have a cable connection
if u hav cable connection den its very easy just connect ur cable and open windows media center. thne go to settings from there to tv and den set up tv. go for cable den no to set top box den analog cable and finally scan u will get all the channels. NjoY.
Aug 08, 2011 | Lenovo IdeaPad Y560 Laptop
Hello,everyone!! i have lenovo ideapad y560 with inbuild tv tuner & also a connector wire to connect dish cable to laptop... but my question is that how do i watch tv on my laptop OR in which...
Hi
TV tuner cards allow you to view programming on a computer system. Although desktop computers allow you to install internal TV tuner cards, laptop systems do not have the available space for internal cards. Because of this, laptop computers have PCI express card slots. This slot allows you to install and remove (at your will) additional hardware, such as TV tuner cards.
  • TV tuner card
  • Driver installation CD
  • Software installation
  1. Locate the PCI express card slot (located on the side of your computer opposite the disc drive). Push in on the protective cover on the slot to unlock it from the case. It pops out slightly, allowing you to remove the card.
  2. Slide in the TV tuner into the PCI express card slot. The card clicks into place and a light blinks on when the card has connected successfully to the laptop computer.
  3. Insert the driver installation CD into the disc drive of the computer. Momentarily a driver installation wizard appears on the screen. Click "Next" on the welcome page, then accept the given license agreement. Choose "Next" two more times, then select "Install" and the drivers from the driver installation CD install onto the computer.
  4. Eject the driver installation CD and insert the software installation CD. This is the program you use to view the connected receiver. As with the driver installation CD, wait for the installation wizard to load up onto the screen. Accept the license agreement, leave the installation name and location blank, then click "Install" to install the software.
  5. Restart the computer. Upon restart the laptop is ready to begin using the TV tuner card.
Jun 12, 2011 | Lenovo IdeaPad Y560 Laptop
I purchased lenova y560 with ms office 2010,but dont know product key
HI,
Do you have the installation CD of MS Office also his cover and everything? If yes check the labels on the cover. Im sure it is written..
Also check your cd if they gave you a genuine CD of the MS application.
Mar 19, 2011 | Microsoft Office Home and Student 2010
How to use in built TV tuner in lenovo y560 laptop
In windows 7 - Windows Media Center will use it (NOT media PLAYER, media CENTER)
media center is actually wicked cool for watching TV because if you have cable, no more waiting for the listings channel...it pulls up to 2 weeks of listings from your provider, so you can schedule shows to be recorded, record series etc...very cool!
Mar 03, 2011 | IBM Computers & Internet
I have Lenova Idea Centre B300, Planning to purchase a TV TUNER CARD, can you please suggest me proper TV tuner card for my system.
An External or USB TV tuner Will be ok. Just make sure its compatible to your OS (Vista WinxP or Win7).Thanks.
Jan 27, 2011 | Lenovo IdeaCentre B305 (40311RU) PC...
SIR I HAVE LENOVO Y510 IDEA PAD . AND XP OPERATING SYSTEM. I WANT TO SEE TV ON MY NOTEPAD. I ALSO DOWNLOAD THE XP TV TUNER DRIVER FROM LENOVO SITE. SIR LENOVO SUTTAL CENTER WHEN I STAR AND TV CABLE...
>What is the model of your Y510?
>First make sure that the model of your computer is the one with TV Tuner on it (Y510 with model number 7758-44Q has a TV Tuner on it)
>If you do make sure you installed the driver compatible with your Operating System
>if you look at this link:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=12
>it will show you 2 drivers for the TV Tuner one compatible with Windows Vista 32bit and Win XP
>If you are sure you have downloaded the one for XP then just tweak the settings of yuor TV Tuner and look for LIVE TV.
these are just tips and not a total resolution to the problem but still your comments suggestions ratings and testimonials will greatly be appreciated
Sep 23, 2010 | Lenovo IdeaPad Y510 Notebook
Lenovo IdeaPad Y560 Laptop Logo
439 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
