Question about Pioneer Audio Players & Recorders
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that accomplishes this task. How do I repair this problem? Thanks, Dennis
  • 11,361 Answers
You need to clean out and refill the tonearm lifter cueing damping fluid, http://www.turntablebasics.com/silicone.html
The cueing arm that lift and lower the tonearm is filled with Silicone damping fluid which will dry out with times.
You can also Google Silicone damping fluid.
Posted on Mar 24, 2011
  • 1,591 Answers
Most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Posted on Mar 23, 2011
How do I access tone arm belt and motor on a Pioneer PL-L30 turntable?
Try lifting up the turntable mat. You should see a hole. Note how it fits before removing the belt.
Oct 10, 2014 | Audio Players & Recorders
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
Converting a turntable from automatic to manual
I suppose the only way to do it would be to stop it functioning completely. The only way would be to dissasemble the auto function. What you would need to do is work out which parts are essential for the turntable operation and which only activate the return. So you need to whatch the mechanism working. You will need to remove the base and look at from underneath, just like going underneath a car!
I can't say for certain if you can do it, only you will be able to determine it can be removed without affecting the operation of the entire turntable.
May 21, 2010 | Pioneer PL-990 Turntable
Pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Jan 10, 2009 | Pioneer PL-990 Turntable
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
Sep 16, 2008 | Pioneer PL-990 Turntable
639 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
