Question about Raymarine S100 Remote Control
My new Raymarine S100 remote shows Searching for network then No Link then No Pilot. Can you help
Beeps continuously
This is almost ALWAYS caused by a poor power connection. Check, lubricate and clean/inspect your power cables. I have seen poor solder connections or corrosion prevent the ST 2000+ from getting the horsepower it needs to operate properly.
Hope this helps.
-Steve
Apr 23, 2014 | Raymarine ST2000 Tiller Pilot A12005
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Oct 30, 2008 | Raymarine Computers & Internet
S1 tiller pilot screen says no pilot. voltage input ok,computer problem?,what to do
Go to Raymarine website and look under Technical Support, Manuals and documents. All of their product manuals are listed there.
Aug 20, 2013 | Raymarine S1 Tiller Pilot
Raymarine st 1000 displays 1000 (flashing and beeps) and the actuating rod will not move
Have the same problem, sick and tired of it. It is 18 month old, had repaired once 2 months ago by raymarine, some soldered joints came undone on the board, not working again! Used it 4 times since new out of probably 20 attempts. Every time I try to use some new problem raises. Possibly just my luck. Just ordered a new Navico st 32 heard it is better unit.
Jun 10, 2012 | Raymarine St1000 Plus Tiller Pilot
I have changed my boat and have kept the ST2000 and S100 remote and the wireless base to fit on my new boat. Is it possible to get a wiring diagram to fit this to my new boat please
HI!
We have the same setup on our vessel.
Here's the link from Raymarine for instructions to install your base unit: http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=1020&PRODUCT=3036
(Click on Base Station & Controller installation)
And here is the link to your owners manual for your ST2000+:
http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=87&PRODUCT=19
(Click on 81130 6.pdf)
These contain all the wiring information you need to get it done!
Happy Boating!
Jan 24, 2011 | Raymarine ST2000 Plus Tiller Pilot A12005
I have a One for all URC6011Boo Univerisal remote ,need Code for
lj10863
I have provided a link with instructions for the remote. One option is searching for your code. I hope this helps.
http://safemanuals.com/314159.php?k=2272debd607fb070a5dd97f9763c26a6&ID=1241413&q=ONE%20FOR%20ALL%20URC-6011
Ray Calo
DISH Network
Feb 13, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Raymarine St 4000 Wheel Drive
i had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
Jul 24, 2008 | Raymarine St 4000 Wheel Drive E12093
Raymarine S100 Remote Control Logo
227 people viewed this question
Top Raymarine Televison & Video Experts
Marvin
Marvin
Are you a Raymarine Televison and Video Expert? Answer questions, earn points and help others
