Question about Toshiba Computers & Internet
Need drivers for touch pad - Toshiba Computers & Internet
  • Toshiba Master
  • 32,281 Answers
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Posted on Mar 23, 2011
Touch pad not working light bar not on above the touch pad
Hi Cheryll,
Make sure there are no problems with the driver installed on your machine by going to Control Panel->Device Manager and see if there are any question\exclamation marks on one of the drivers. While you are at the device manager you can check the touch pad driver version and update it to the latest from the manufacturer website if needed. To check the driver version double click the touch pad and go to the Driver tab. You will see it under driver version.
Also some netbooks got an hardware button to shutdown the Touch Pad.
Regards,
TheSmacker.
Jan 21, 2014 | Toshiba Satellite A205-S4617 Notebook
My touch pad not working probably .
Adel Heider,
You may want to first download the driver and install it into the system from the link below.
Inspiron 1545 Drivers Download Page
http://dell.to/14IpAJU
Erratic Pointer Movement
Here are some easy steps to take to determine the problem with a touch pad demonstrating erratic pointer movement:
  1. Get the latest driver from support.dell.com - Most problems can be corrected with a simple driver download. This should always be one of the first steps when diagnosing any touch pad problem.
  2. Check for hand and finger placement - The most common cause of random pointer movement is that the touch pad senses a finger or part of the hand near the surface of the device.
    • Have the customer attempt to use the touch pad normally but to pay attention to the location of his or her hands and fingers. Are any straying too close to the touch pad?
    • Adjust the Touch Sensitivity and TouchCheck settings in the Touch Pad Settings section of the Dell Touchpad Properties.
  3. Try an external mouse - Does this problem happen with an external mouse attached?
    • The Device Select section of the Dell Touchpad Properties has options to enable or disable the touch pad or external mouse. Try several combinations of these settings.
    • If the problems only occur when the touch pad is enabled and do not occur any time a mouse or other external device is used, then the issue is related to the touch pad.
  4. Check for mechanical problems - If the problem cannot be corrected by adjusting the settings mentioned above and only occurs with the touch pad enabled, then this could indicate a mechanical problem.
    • Press down on the palm rest on first the left side of the touch pad and then the right. See if the cursor starts moving on its own.
    • Run Dell 32-bit Diagnostics and try to recreate the problems there. If either of these situations occur, then replace the palm rest.
No Pointer Movement
No pointer movement from the touch pad (or track stick, if available) usually is the result of one of two things: The touch pad has been disabled in the driver interface, or the touch pad cable is damaged or disconnected. Follow the steps below to determine the problem.
  1. Connect an external mouse - In either situation, an external mouse should still function. If it does not, try booting into Safe Mode and testing both devices again.
  2. Enable the touch pad in the driver settings - Using the external mouse (or key strokes if no mouse is available), go into the Dell Touchpad Properties. Go to the Device Select section and enable the touch pad. If already enabled, get the latest driver from support.dell.com.
  3. Test the device in Dell 32-bit Diagnostics - To eliminate a potential software problem, run the Dell 32-bit Diagnostics and test the device here.
  4. Check for mechanical problems - As a last resort, press down on the palm rest where the touch pad connector is located on the system board. If the pointer reacts in some way, then the cable may just need to be reseated. Otherwise, replace the palm rest.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 07, 2013 | Dell Inspiron 1545 Notebook
I have a dell vostro A860 laptop.not working to Touchpad. How to Fix Touchpad Not Working in Laptop
What you can initially do is to update the driver.
  1. Press on the windows key + R. A run box will appear.
  2. Type devmgmt.msc then click on ok. The device manage will appear.
  1. Click on the plus sign besides mice and other pointing devices.
  2. Right click on the item that will be pertaining to your touch pad.
  3. Choose update driver and let the internet work for you.
If this does not work, you will need to totally reinstall the driver.
  1. On the same screen (device manager) right click on the touch pad driver again, the choose uninstall.
  2. follow the prompts for uninstallation. You might wanna uninstall any mouse related drivers as well (these application can also cause conflicts thus causing your touch pad not to work)
  3. download the touch pad driver available from the link I provided below.
  4. follow the prompts for installation.
  5. restart
Dell Vostro Driver list (click here to view all available drivers for your portable system)
Dell Vostro Touch Pad Driver (click here to download the touch pad driver)
It this does not work, you will need to call Dell Technical Support to have the laptop serviced. That is if the portable still has warranty. If not, then you will need to buy a USB mouse as a replacement.
for additional information visit Dell support website: support.dell.com
Jul 18, 2011 | Dell Vostro A860 Notebook
There are not working the touch pad
Have you checked that the touch pad is enabled, as Acer uses something like the FN F7 keys to enable disable the touch pad.
If still facing the same issue means you need to download the touch pad driver from the Acer website and you can fix the issue.
http://support.acer-euro.com/drivers/downloads.html
Select the product and download the Driver.
Please let me know whether this works or not.
Dec 17, 2010 | Acer Aspire One PC Notebook
Cannot scroll on my touch pad
This usually means you need a driver for the touch pad. Though, not all touch pads are designed to scroll. Go your your PC manufacture and look up your model for support. You should see a driver for the touch pad.
Nov 19, 2010 | Microsoft Windows XP Professional
Scroll is not working
This could be one or some of the 3 issues that may be happening with your notebook or netbook:
1) check control panel (if this is windows) and click on touch pad icon and make sure the sofware to control the touch pad is working and it's on.
2) If it is on, reinstall all touch pad and mouse drivers for this unit by going to the manufature's website and downloading the original drivers for this unit
3) it that does not work, you may have a defective or broken touch pad and it may need replacing
BEFORE CONTEMPLATING A NEW TOUCH PAD, do 1 and 2 first.
They are usually the main causes of touch pad failure and should resolve your issue.
If both fails you may need to order a new part to replace the pad.
I hope this helps. Write me back and let me know how it goes
Jun 14, 2010 | Compaq (153515-001) Touch Pad
Touch pad
If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
Hope that helps :)
Mar 13, 2009 | HP Compaq Presario 2200 Notebook
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Nov 04, 2008 | Logitech V220 Mouse
Touchpad
When the touch pad stops working it's one of three things. 1- A driver glitch, unistall the touch pad drivers from the device manager, then reboot. The machine will find the touch pad and reinstall the drivers automatically. 2- The touch pad connector has worked loose. Take the palm rest with the touch pad off, disconnect the cable, clean the connectors, and reseat the cable firmly. 3- the touch pad has failed and will need to be replaced. The driver glitch is the most common, I believe that it should take care of the problem. Let me know.
Aug 06, 2008 | Dell Inspiron E1705 Notebook
Touch pad driver.
Uninstall the driver from the device manager, then reboot. The machine will find the touch pad and reinstall the drive automatically. If this doesn't work, check the touch pad connection, they will sometimes work loose ar get a little dirt/corrosion build up. The connection is under the keyboard. At this point, if it's still not working, then it has failed and will need replaced.
Jul 20, 2008 | HP Compaq nc6220 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
