Question about Brother FAX-8360P Plain Paper Laser
There is a black line on the right hand side since the toner has been changed
  • 903 Answers
There is probably a defect with the new toner cartridge, either on the drum itself or somewhere else inside the cartridge. You'll need to replace it with another one.
Posted on Mar 23, 2011
Black line on right hand side of the pahe
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jan 22, 2013 | HP LaserJet 2420 Printer
I get a black line about 3mm from the right hand edge and faint specks which look like they have been created by a wheels but are much more concentrated on the lower left hand side. Do I change the fuser...
Vertical lines and evenly spaced marks are typically caused by damaged drum. The drums are usually in the toner cartridges. If you think its coming from a a roller or wheel you should be able to just clean off the roller/wheel. The fuser is simply what melts the toner into the paper so I doubt that is your issue.
Try cleaning the rollers and wheels. If that doesnt help replace the drum/cartridge if they are combined.
Sep 03, 2011 | Lexmark C510 Laser Printer
Solid black line on the right hand side of the page. will changing the the toner cartridge fix it
Probably NOT the toner cartridge. More likely to be the drum cartridge. Pull out the toner/drum cartridge assembly and remove the toner cartridge from the drum unit. Now look carefully at the drum. This is the greenish/Blueish colored cylinder. If you see the black line going around the drum on one edge then that will be your proof that it is the drum unit. You can try cleaning the corona wire by sliding the little blue tab there on top of the drum unit back and forth a few times.
Good Luck and Thank You for using Fixya.
Sep 12, 2010 | Brother HL 5140 Laser Printer
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Epson C1100 K toner low, right hand side can't print
Well if the margins are not the issue, then I would change it.
But before that, try taking a cotton swab, and cleaning the "k toner", the bottom part where the ink comes out. This way before investing more money into your printer, this 'k toner' might just needed a bit of cleaning.
Good luck
Sep 10, 2009 | Epson Aculaser C1100 Printer
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
My DELL 3010CN is printing a thick black line on the right hand margin on all pages printed.
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Apr 08, 2009 | Dell 3010cn Laser Printer
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Brother FAX-8360P Plain Paper Laser Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
