We have small grease like marks left on some clothes after washing.
  • 2,510 Answers
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
Posted on Mar 23, 2011
Leaving dirty marks after washing
grease or rust ?? if its rust then you most likely have an exposed metal part that has rusted (look with flashlight and mirror at edge of agitator) if its grease then you can try washing it out with a little bit of grease cutter and many non clothes washes afterward
May 27, 2016 | Washing Machines
Loud noise when spinning black marks on clothes leaves drum circle marks on clothes
it sounds like the bearings have gone ...are the marks on clothes oil marks ? or grease marks ? this is a sign of bearings. if there rubber marks it will be your door seal thats gone ( dose it leak )
May 05, 2015 | Beko Washing Machines
Grease like stains on clothing after washing
You have to clean the filter once a month. Which located lower left. Do a tub cleanse. Rinse extra. That will clear your problem. I have had the same issue and many repairmen and that was the answer. As long as I clean it than grease marks
Jul 30, 2013 | LG WM2301HW Front Load Washer
Oil on cloths after wash
Simpson washing machines are known for this, The seal in to top of the gearbox fails which allows water to enter the gearbox, this forces the grease out of the gearbox into the machine, The fix is an expensive gearbox swap.
Mar 11, 2012 | Simpson Washing Machines
Oil marks on my clothes after washing
It could be an indication that the main bearings are failing, or it could be an effect known as grease balling.
This is caused by washing at too low a temperature, or not using enough powder, or using the wrong type of powder.
If it is the bearings, then I would expect it to be getting noisy, particularly on the spin cycle.
Hope this helps.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Select Brands Washing Machines
Grease on clothing, AGAIN. Have had the wash plate replaced, but the problem returned within a year.
Try changing your detergent. I believe it was Tide that caused dark grease type marks on my clothing. It hasn't been a problem since I changed detergents.
Jun 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Marks on clothes
Hi. Souds like an Effect called ****. Usually caused by not using enough powder, or washing at too low a temperature. You should do a boil wash at least once a month with powder in but no clothes in. It is called maintenance wash. Always wash at the recommended temp on the wash care label. Good luck
Nov 19, 2008 | Washing Machines
Black marks on clothing
Sounds like grease or oil from transmission may be leaking and finding its way into tub.
Nov 03, 2017 | Kenmore 43142 Front Load Washer
Black oil or grease on clothes after washing
is you machine a top loader or front loader? if its a front loader the black marks could be from the boot. WIpe the boot with a good cleaner. and try not to over load machine. and if it a top loader your transmission is probably leaking oil back into clothes tub. You could have it rebuilt $$$ or better replace the machine.
May 22, 2008 | Washing Machines
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
