Question about Dryers
My westinghouse dryer ld505 installed but it is only beeping & drum is not rolling? can u advise please.
3 Suggested Answers
  • 74 Answers
SOURCE: Dryer drum doesn't sart rolling when it is turned on.
It is not using the start winding in the motor. You might be able to remove the end bell and clean the switch?
Posted on Apr 24, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Model DLE2516W Dryer sounds like something is
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
And also the noise could be the front seal is out of alignment or broken and this may cause the machine to be slower in tumbling.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. Now you should be able to see the front seal and see if it is ok and now this will also expose the drum and belt Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Oct 26, 2009
Need help refitting the tension spring and belt to a Westinghouse dryer
You need to feed the belt around the tensioner first but release the tension from the tensioner. Place something under it to keep it from expanding open and the feed the belt onto the drum. If you get it started you can turn the drum and it will feed itself onto the drum. Once that is done, align the belt visually for straightness and gently release the tension. Voila
Aug 05, 2017 | Westinghouse Dryers
Tip
Westinghouse Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For all Westinghouse models use this diagram:
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
My frigidair affinity dryer wont start it just beeps
Good Afternoon Friend,
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Westinghouse de600a0dw2
You'll have to trouble shoot it... the belt either jumped off the motor pully or it may have broke. Either way you'll have to disconnect it and inspect it. Remember to always unplug the unit when servicing it. If the belt broke it is not hard to replace. The drums are held by gravity on rollers. Simply lift enough to get new belt pass the roller. If there are upper rollers in the way... simply remove them. Don't remove lower rollers. Lift the drum enough to install the belt and replace the upper rollers, relocate the new belt and close it up. Done.
Dec 25, 2013 | White-Westinghouse White Westinghouse...
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Older model dryer--drum will no longer spin. Need
The model number you provided is for a White Westinghouse. In order the access the internal cabinet to view the drum, you will need to lift the top panel. This is accomplished by inserting a putty knife along the front seam where the top meets the front of the dryer. About 2 inches in from each side is a small retaining clip. Push in with the putty knife and the top should pop free and lift up. The belt should be visible around the drum if it still intact. If the belt is loose, or missing, it has probably broken.
NOTE: The only way a belt will come off the drum while enclosed in the cabinet is if it breaks.
CAUTION: Make sure you UNPLUG the dryer before servicing. Dangerous voltage is still present inside the dryer even with it turned off.
To access the drum to replace the belt, you will need to remove the front panel. Remove the lint screen and lint screen cover in the door, first. Then, remove any screws holding the panel in place. The belt can be installed with the drum in place. Simply loop it around the drum first, then feed the remaining portion of the belt behind the blower fan housing and loop it on to the drive motor pulley and belt tensioner.
The part number for a replacement belt (if required) is 134503600. You can purchase a new one at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Prices vary between these sites, so shop around for the best deal. The first three sites also offer very helpful exploded view parts diagrams you can use as reference. Repairclinic.com will have diagrams to show up how to properly route the dryer belt. Just click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram G under Westinghouse.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: If the belt isn't the problem, please let me know.
Oct 10, 2009 | Dryers
Our Whirlpool Duet dryer won't run. After selecting a cycle and pressing the start button, it beeps twice and the time flashes. what can we do to fix this?
Make & model # please. When the "time flashes" are you sure it is the time or is it an error code like F3 or maybe F10? Please advise.
Oct 08, 2009 | Whirlpool GEW9250 Electric Dryer
Model: maytag LDE9606ACE reinstall belt
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, look for the "Dryer Belt Diagrams" link under the "Special Features" section. Refer to Diagram E for a Maytag dryer. If you have questions, please let me know. I hope this helps you.
Sep 25, 2009 | Dryers
Apr 24, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
Top Dryers Experts
