Question about Kingston Electronics - Others
Windows was unable to install your DT 100 G2 - Kingston Electronics - Others
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: can not format the usb
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
hope it helps
Posted on Aug 13, 2011
Tip
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP Home)
DRIVER NEEDED: Hitachi hl-dt-st rw/dvd gcc-4241n (Windows XP) [IDE]
Simple solution:
Situation
There is a yellow exclamation mark for CD/DVD drives in Device Manager. The device status in the properties of the driver might indicate an error code, for example 32, 37, or 39. Or the drive simply does not appear in My Computer or Device Manager.
Solution
To solve the issue, you have to edit the Windows Registry:
Click Start, then Run, type REGEDT32 and click OK.
Locate and then remove the following registry values:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}LowerFilters
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***{4D36E965-E325-11CE-BFC1-08002BE10318}UpperFilters
Close Registry Editor.
Reboot the system for the changes to take effect.
Note: Some programs are unable to detect the CD/DVD drive after these steps. To solve this, simply re-install the program in question, eg: usually your recording software. Also, in few instances the order in which the programs are (re-)installed can make a difference.
on Sep 12, 2010 | Computers & Internet
USB Mass Storage Device(Kingston DT 101 G2)
Name: Kingston DT 101 G2 (USB2.0)
Logic Driver: L:\
VID&PID: Vid_0951&Pid_1642
Speed: high speed
VendorID: Kingston
ProductID: DT 101 G2
Product Revision: 1.00 what s the softwar for this flash??
Feb 10, 2014 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston dt101g2
if u can format your device format as fat32....before format keep your data...
Jan 02, 2014 | Audio Players & Recorders
16gb pendrive
try to format it using this program http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
May 22, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
Can not format the usb kingston DT 100 G2 device and shown capacity 0 byt used 0 byt free 0 byt and unknown file system shown
hope it helps
Aug 13, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I need to buy a tweeter for my speaker can you help me.
hi,
As it hve a horn tweeter no need to replace the whole unit. You will get the diaphragm. go the following page check the third item. Its the diaphragm for JBL EON 15-G2. An the order code is
DT-004.
http://www.goodhifi.com/MyDias/Diaphragms.htm
ok
Aug 03, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I purchased LG SATA DVD writer after installing it, unable to read any CD or DVD. Its detected in device manager but cant ready media. tried to SATA cable & SATA port, still same. Another thing i...
Can you hear it "spinning" the media? If not, you have a "defective" unit (motors or bearings).
If it spins, but nothing is read, then you have a "defective" unit (dead laser).
Take it back to where you bought it, and get them to test it, to prove that it is "bad", and then for them to replace it.
> in Hardware details it shows HL-DT-ST DVD RAM GH24NS50 SCSI CDROM Device.
Normal for most SATA devices.
> it shows as HT-DT-ST CD-RW GCE-8526B ATA device.
Perfectly normal.
Feb 21, 2011 | LG GH24NS50 DVDRAM Burner
Configure & install two scsi disks scsi disks in ML 150 G2
The SCSI driver is required to installed during the initial boot up for installation when additional drivers are asked .the new models dont come with a Floppy drive so an external floppy drive can be used .The detection of HDD s must be at the startup by the Bios os SCSI card.
Feb 24, 2010 | HP ProLiant ML150 G2 Server
Hand microphone for DT 100 does not work. Need replacement mic
MR-9 Microphone for DT-1000
The MR-9 Microphone allows direct dictating to the DT-1000 Transcriber and also permits you to control the playback functions remotely. Remote playback functions include Listen, Fast Forward, Rewind, and Stop. Cord extends to approximately 6 feet.
http://www.olympusamerica.com/cpg_section/cpg_audio_acc.asp?val1=1&accessory=76
Jan 28, 2009 | Olympus Pearlcorder DT1000 Desktop...
Electronics - Others Logo
71 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
