Question about Power Up TC3J-4030 P ATX Mid-Tower Case
Won't turn on or power up. At first I thought maybe my CPU had died, so I replaced that and it took 2-3 attempts to actually get the unit to power up. I suspect that maybe my power supply is toast. Has anyone else had this problem?
  • 31 Answers
Yes many times, it usually is power supply..not very hard to replace.
Posted on Mar 23, 2011
LG LCDTV 60LD5 turn on TV logo appears and nothing else. Standby indicator flashing. Help
This happened to our tv so we took the panel off the back and realized the power is actually still on but the screen goes black so that's why I thought it was turning off. Actually the power is ok but found that the connector cable that connects the slave 1 and 2 board is burnt. Now we just need to figure out how to order and replace those boards and the connector.
Sep 13, 2017 | LG Televison & Video
D2X won't power down!!
Sounds like there is a problem with the image compression board. Send it to Nikon - replacing the board requires programming with Nikon's proprietary program.
Apr 09, 2013 | Nikon D2X Digital Camera
Key turns freely in deadbolt, but suddenly won't engage the lock
get in a locksmith ( possible ******* entry attempt damaged the tumblers)
or
replace the lock unit
Nov 20, 2017 | Locks & Locksmithing
My 6 year old Whirlpool Sport Duet washer will rarely stay running for a whole cycle. The power switches on and off on its own...it adds extra rinse cycles and won't allow you to turn them off, it...
Hello & Welcome to FixYa
I Agree, I don't think it is any other board, I believe the CCU (central control unit) has gone bad as it keeps on stopping mid cycle. If it was the Motor Control Board (MCU) then the washer motor should have been causing problems (which isn't the case) so replacement of CCU will be a great option. Please get back to me if you have any other questions.
Kevin
Sep 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My 2yr old whirlpool dishwasher model# DU1145XTPBA, ser# FU3026019, 2.7 amps, type# 5750-0 has stopped turning on. I never had any trouble out of it and now it won't turn on. I thought maybe a fuse...
It is possible the thermal fuse located in the control panel has blown.
See item 5 in this diagram. You could attempt to replace it.
make sure the power is disconnected when you are working on the dishwasher.
Hope this helps.
Jun 21, 2011 | Whirlpool Dishwashers
The whole unit switches off after about 30 minutes. I thought it could be heating up and cleaned the fan (externally), put it on 1/2 inch brackets to ensure air circulation, changed to a different...
If you suspect thermal issues maybe you could verify that the unit actually feels hot when it dies. If not, it's some other cause.
Is the now-clean fan working?
I'm sure the manual of this unnamed component might give some clues as well as what the proper physical clearance around the unit should be maintained.
Aug 03, 2010 | Audio Players & Recorders
Took my bike out, WR450f 07 model, got to the shop and had something to eat, came out and bike wouldn't go, headlight globe was blown, actually smashed, was no spark so replaced spark plug and checked...
My thoughts...Light globes are made to withstand voltages of less than 16 volts. So if you are finding your headlight globe burnt out, it's because the system voltage has exceeded this. Have your voltage regulator replaced which will remedy the problem. Over voltage will have an effect on other electronic components such as the CDI unit and wreck your battery too.
Apr 07, 2010 | Yamaha WR 450 F Motorcycles
Toshiba Intel Core 2 Duo Processor T5750 died
Hello
Is not necessary to be the CPU,maybe is the power adapter,motherboard or CPU.
First check your power adapter,try another one from a friend or buy one.If you notice even one led flashing or something even a led near the hole that you plug the adapter(some laptops have a led there) then is not your adapter.
Good luck and let me know
Jan 13, 2010 | Toshiba Satellite A205-S4617 Notebook
For 3 weeks My Dell 4700C had difficulty starting. It took from 3-6 attempts to start. In the 3rd week the fan began to sound like a plane starting up. It would get louder and louder until I thought it...
hi have you heard any beeps when pc starts they tell you whats going on 1 beep all good and so on what ive found over the years is some times things need to be reseated turn pc off unplug try to start to drain power touch psu with hand on metal to earth then take ram out and reseat it same as batt take out try to start with no pwer to drain board again but in go in to bios change any setting like which hard drive you want to start first tell me how that goes cheers mate ps i never heard of cpu being limited by ram its you motherboard and os system which deside how much ram you pc can handle 32bit can read 4 gigs 64 bit over 12gigs
Oct 17, 2009 | Dell Dimension 4700 PC Desktop
I am attempting to isntall a new biostar am2 socket micro board with a sempron cpu. I get everything connected, but when I turn on the power from the front panel, the fans will spin for a moment, then die...
take out CPU and switch it on - do you get the same behaviour?
If so then CPU is probably wrong sort - check model of mainboard and CPU.
If behaviour is differnt then fit CPU and remove ram - if it beeps then CPU is working. Replace RAM and disconnect ALL other devices (hard disk, CD, front panel connect cable, reset button) just leave fans and power plugged in. now short out two pins for power on switch and see if it starts up.
Aug 08, 2008 | Biostar Computers & Internet
Power Up TC3J-4030 P ATX Mid-Tower Case Logo
77 people viewed this question
Top Power Up Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Power Up Computer and Internet Expert? Answer questions, earn points and help others
