Hi, My machine keeps stopping during the cycle...all the lights stay on but the cycle stops. I have to power off then on to get it to continue...this happens about 4 times during each wash. Now when the wash is finished the clothes are clean but very very wet. Any ideas? Many thanks
  • Washing Mach... Master
  • 17,130 Answers
It seems that the program controller is faulty and needs a check. The program controller is not initiating the spin cycle. So during the cycle the voltage on the motor must be checked so that it will be confirmed if there is a fault on the processor due to a loss of voltage to drive.
Now once this is confirmed the program controller can be confirmed. if not it can be a resetting due to a loose connection on the board and it must be checked, tighten all lead and check.
Posted on Mar 23, 2011
  • 822 Answers
Could be pump blocked..........which will stop machine
a penny is the ideal size to block the pump..........
cheers
Our Whirlpool AWZ412 washer/dryer just stopped during the wash cycle. It did seemed to have moved 5 cm out of place, possibly due to a disbalance during the cycle. We tested the outlet, swiched the machine...
This could be the door latch switch that has failed or came loose, it may also be that the off balance load caused such a bad vibration that the wires have come loose or broken to the motor.
Dec 15, 2017 | Whirlpool AWZ412 Front Load Washer
Keeps stopping during wash cycle
Hi Kathy,just read your posting.When the machine stops during the cycle does the machine beep and show an error code?Could you confirm the model number of your machine.Now if you have an LCD screen on your machine the fault code will appear in it but if you have no screen then the error code will appear as lights .These lights will be a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher stops during cycle and full of dirty water
you are having a problem with your door latch.the unit may not be staying closed or the latch strike is not in position to engage the door switches.
check the metal bracket just where the door closes and try to bend it downward , closer to the door and see if this helps to keep it working.
Jan 20, 2010 | Dishwashers
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Machine won't start
Hi there
i'm not sure if the fisher and paykel machines are any different in new zealand compared to where you live, but the only thing i can think of if it isn't displaying a fault code is if this machine is fitted with a reed switch(these make sure the machine stops if the lid is opened during operation) this may be faulty and staying open causing the machine to stop when the lid is closed. Hope this helps.
Jul 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Machine stops during the wash cycle.
Hi this is abhishek,welcome to fixya
over weight normally doesnt cause machine to stop during the wash cycle,,iit is actually tub gettiing stuck or a timer problem...
thank uy........
May 03, 2009 | Bosch Logixx WFR 2867 Front Load Washer
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
Machine off balace during washing then stopped working
could be either interface control(pushbuttons and knob) or machine control (gray plastic box)
Jun 01, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
