Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Power shut down during os installatrion. - Foxconn 45CMX socket LGA775 motherboard (16897)
  • Foxconn Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 23, 2011
Dell laptop shuting down problem
I would try running a registry cleaning programme as it may be stuck in a loop and also check for a BIOS update from Dell.
Jan 12, 2014 | Dell Latitude D600 Notebook
My mac book air is not shutting down..i just can see a desktop background and a coloured disk..
To have a try like this,put off the power connect wire,and took off the laptop battery for Makbook,it must be shutter down.Then restart it again! Good luck.
Feb 28, 2011 | Apple MacBook Air
Hi Have a Dell Pc Windows 7 OS. it will not shut down unless I hold the button. Start-up in good shut down is always a problem
This is a possible malware or virus attack. Your system is encountering data or system corruption preventing it to execute the command during shut down. Best fix is to reinstall Windows 7 in your computer to erradicate all errors and make sure to install an updated security software (antivirus) afterwards.
Jul 16, 2010 | Dell Vostro 200 PC Desktop
How do i turn off the dos mode on my mac
The quickest way to get out of DOS is to hold down the power key until the computer shuts off. Then during restart, hold down the option key until the drives icons appear on screen. Use the arrow keys to select your OS for start up and away you go..
K
Oct 21, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer hard drive is allways active even in the middle of the night...?
Yes, Windows OS's are continually updating swap file which exists on the same drive has the OS. If you computer not actively being used during the night, you should set your power management options to reflect. Most have option to shut down monitor, hard drive and entire system after so many minutes. You can define these parameters for when plugged into AC power or running on battery. I suspect you have these set to always on when connected to AC power.
Oct 12, 2009 | HP Pavilion dv6000z Notebook
Macbook was manually shut down during an update
while starting, hit cmd v. this will put it into verbose mode and show the background processes and where it stops, there will be your problem. Also try inserting an OS disk and hitting c during startup chime and use the disk utility to fix the permissions.
Jun 04, 2009 | Apple MacBook Mac Notebook
Won't complete booting
Sounds like at the very least, the hard drive is. This is common when a file required by the OS is corrupted, and the OS tries to not damage data so it restarts or shuts down.
Jan 18, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
41 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
