Question about Qep 60087 Table Tile Saw 7" Wet
Need manual for 7-inch wet tile saw Qep 60087
    Novelist:
  • 157 Answers
Hello. Found the manual for you at:
http://www.northlandconstruction.com/products/4125/techsheet/QEP%2060087%207in.%20Wet%20Tile%20Saw%20Brochure.pdf
If this helped, please rate a four thumbs on this answer.
Thank You.
Posted on Mar 23, 2011
I have a QEP 7" tile saw. When I plug it in and press the switch, it hums-blade does not spin. (Note: not ready to cut tile yet, so no water in the bottom) Does anyone have any ideas on what's wrong?
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
Feb 12, 2016 | Qep Saws
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Where do you put the water?
Most wet saws have a water tray below the table area. The blade moves thru this tray and gets cooled and lubricated by the water
Mar 06, 2015 | Qep 60087 Table Tile Saw 7" Wet
Switch won't work
Take it apart and fix the switch or put a new, different switch in the circuit. May just be a broken wire. Jack
Nov 23, 2013 | Roberts 10-22500 QEP 7 Tile Wet Saw
What direction for blade rotation
The top of the blade spins toward you, but maybe you are asking which way the blade should go? If this is a tile saw, the teeth are tiny bits of diamond and will work in either direction. If this is blade with visible teeth, as for cutting wood, the points of the teeth should be toward you on the top of the blade. Good luck.
May 26, 2012 | Qep 60087 Table Tile Saw 7" Wet
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Mar 16, 2011 | Wet International Q.E.P 4 inch Portable...
Were can i find denver unika basic bridge saw instruction manua
you can find all manuals and parts list for qep 83200 at this site:
http://www.qep.com/products.php?c=1&cat=1&sub=17&prod=5
if you find my advice helpful, please do not hesitate to leave your comment and vote4 for me, thanx!
Aug 01, 2010 | Qep Tile Tools 83200 24inch Bridge Saw
Where does the water go?
Generally you can take the top off and the water goes in the bottom just under the saw. As far as the level goes they usually have a fill hole that when filled up all the way it will start to run out. If not, just make sure the blade is in water for about an inch or two.
Aug 03, 2009 | Wet International Q.E.P 4 inch Portable...
Qep 60087 Table Tile Saw 7" Wet Logo
1,248 people viewed this question
Top Qep Saws Experts
JOHN LAPIER
Terry Hair
Tom Chichester
Are you a Qep Saw Expert? Answer questions, earn points and help others
