Question about LG Televison & Video
I wish to connect My LG television (modelCA-20D69) to a video machine so my grand kids can watch some videos they like. On the TV, do the white and yellow connections, plug into the out video and out audio holes? Then in turn, does the other end of the yellow and white cables plug in the "Video in & audio in" slots in the video machine. Or, is the whole process the reverse? Grateful for any assistance. Many thanks Mike
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • LG Expert
  • 177 Answers
Hello Mike,
Thats correct.
From Video Player : generally Yellow is video out and white or red is audio out. Than;
Rear or side TV : plug in yellow as video in from video player , white or red as audio.
You can plug in different configuration like above, but mark each connection.
Good luck.
Posted on Mar 23, 2011
  • 822 Answers
In reverse...... easier to use a scart cable..........
cheers
I have a standerd tv and i want my kids to use it and watch netfliex, how do i connect it
  1. A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set.
Aug 01, 2014 | Televison & Video
I Have recently Purchased a new LG 22" HDTV and want to connect to an older style video recorder. should i connect the old RF way and if so what input do I select on LG remote.what channel should I...
Your old video recorder should have the cable with the red, white and yellow connection. Plug them into the red, white and yellow boxes in the back of the TV. Usually there is a small white box painted around those three boxes and it says "Video 1" or "Video 2" on it, depending on how many video connections you have. If you turn on your TV you need to push "input" on your remote control and select the option "Video 1" or "Video 2", it needs to match with where you plugged it in the back of the TV.
May 04, 2011 | LG Televison & Video
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
I can't tune my tosihiba vcr into my sharp tv
If you are using an aerial lead to connect it, put a video in the machine and press play.
Turn the TV into its RF search mode on the channel you wish to watch video on, say 9.
When the picture of the playing video apears, you have been succesfull! Store the channel.
If you are using A/V keads or scart connectors, play a tape and with the video connected to the TV, select which ever AV/EXT channel it is connected to.
Hope that helps.
Nov 20, 2010 | Televison & Video
How do I plug in my dvd player to this rca 52 in
the red and white rca wire stands for audio (sound) and the yellow stands for video(display).
So connect the red, white and yellow wire as Out from the DVD and connect it to In of your TV.
After the connection, press AV from your TV remoter in order to watch your DVD on your TV.
Best wishes.
Mar 12, 2010 | RCA P52926 52" Rear Projection Television
Can I hook up my tv wirelessly to my home network?
Well I have, using those 2.4GHz AV Video/Audio Senders/Receivers, and as long as the PC you wish to watch has Composite Video OUT, then you can connect the "Sender" to the Video & Audio OUT, this in turn is "Transmitted" to the Receiver, that OUTPUTS again composite Video & Audio to the TV's Composite Video IN and AV IN. Yellow Video & Red & White are Audio IN. Works a treat.
Feb 15, 2010 | Toshiba 32A33 32" TV
Wife was watching tv and the picture went out. We currently have direct tv for the service provider. Tried watching a dvd and had the same result. However, sound works on the tv just no picture.
I would start by obviously checking all connections on the back of the tv. Sounds like maybe your Yellow RCA cable might have creeped out. Red and White RCAs are typically for sound and Yellow is for Video. Hope this helps
Nov 18, 2009 | LG 50PC3D 50 in. Plasma Television
Watching television on Philips Freevents MT2700
Did it come with Windows Media Center?
You will need a TV Tuner to watch TV. There are internal cards or USB types.
Mar 20, 2009 | Computers & Internet
Televison & Video Logo
