How do I open/unlock part way through a drying cycle?
  • 1,998 Answers
You would hold down cancel or stop for 5 seconds usually the cancel option puts the unit into drain in which after it finishes draining it would unlock the door on the other hand if you had a door switch error and your unit was a frontload washer and you are unable to get into the unit even after the unit has stopped you would remove the lower panel on the machine and reach up along the side that has the door lock there would be a small cord with a round circle on the end by pulling this cord down this also unlocks the door this 2nd par is only for a frontload washer if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks
Rick
Posted on Mar 23, 2011
Control lock light is on , toke door lock off once cleaned it put it back on and it worked now its on aagain and washer wont work
1 close washer door and dispenser drawer
2 select Clean washer cycle
3 Press start/ pause
The basket will rotate,then the door will unlock,lock again,then the cycle will continue
Water should come in and run a short sensing cycle about 3 minutes
4 This will determine item in the washer
a if no items are detected it will move to step 5
b if item are detected wash any control lock light will stay on door will unlock open and remove any garments
If b pessnpower to cancel f code then repeat 1,2,3
Once cycle begins allow it to finish
5 after cycle is complete leave the door a jar to allow for venting and drying of interior
Only use HE high efficiency detergent
Jul 05, 2015 | Whirlpool GHW9100L Front Load Washer
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Is there anyway to only dry the dishes? Sometimes the dishes don't get all the way dry and I just want to run the dry cycle again. Thanks! Dawn
You could simply open the door at the end of the cycle and let the air do the job. If your dishwasher is controlled by a manual dial, you could open the door, move the timer past the wash cycles stopping on the dry cycle and close the door to start another dry cycle. This option is expensive, by the way.
Thanks for your question @ FixYa.com
Sep 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Door will not open
You can reset the control use this key dance within 5 seconds press:
HEATED DRY, NORMAL, HEATED DRY, NORMAL . This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !!
Jul 01, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Door will not open
if there is still water in it use a wet dry shop vac and attach it to the end of the drain hose.once the water is gone it should unlock the lid.then check for blockage.
turn the timer or cancel any kind of wash cycle then unplug the unit for a few minutes this should reset the control to unlock the lid
Apr 13, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag dishwasher Model MDB9150AWQ won't unlock
try this keystroke..."high temp wash" "heated dry" "high temp wash" "heated dry"
Apr 17, 2009 | Maytag 24 in. MDBH950AWS Built-in...
LG7810 will not dry dishes
THE DRY CYCLE HAS A PORT ON THE INSIDE OF THE DOOR WITH A BLOWER MOTOR. THE PORT SHOULD OPEN AND THE FAN MOTOR COME ON DURING THE DRY CYCLE TO EVACUATE THE STEAM FROM THE INTERIOR. THE PORT IS OPENED WITH A WAX MOTOR. IF IT FAILS, THE PORT WILL REMAIN CLOSED AND DRYING WILL NOT TAKE PLACE.
TO VERIFY OPERATION, WHEN THE DRY CYCLE STARTS,
WAIT ABOUT 2 MINUTES, THEN OPEN THE DOOR AND LOOK IN THE ROUND VENT ON THE INTERIOR OF THE DOOR. IT SHOULD BE OPENED. IT WILL SLOWLY CLOSE AS THE DOOR REMAINS OPEN. YOU SHOULD BE ABLE TO SEE THIS ACTION.
Mar 31, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
