When trying to use the lacie network assistant to upgrade firmware to acess the drive I get the message. Lacie network assistant application has stopped working. I have disabled all security stopped windows defender and firewall. This is a windows 7 workstation. with a lacie network space drive If I take the drive from the case I can access data using ubuntu os. Is the network facility in the casing defective? If I format the drive in ubuntu and replace it in the casing could I access it? I have tried this with a seperate blank drive and failed. Is the housing defective?
I also have the same problem, I have loged support call with lacie, but no response as yet... To get you drive back up you need to restore to factory settings.
Posted on Mar 28, 2011
Power applications not supported
That means this won't work on a Power PC. Drive should still work.
Mar 23, 2014 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Sharepoint has vanished
sounds like a job for the admin folks to solve. could be that an upgrade to one of the software products pushed the compatibility of your pre existing network configuration. That does happen at times..
May 22, 2012 | LaCie 4tb 301300U ethernet disk gigabit...
Install 3TB drives in Lacie 5Big Network 2 NAS
What system (full description plz) you're running on? Are you ready to pay for assistance or prefer to call locals?
Jan 22, 2018 | LaCie 5TB 5big Network 2...
I have problems configuring my new d2 Network 2 1.5 TB HD. Either using the LaCie Network Assistant or directly the IP address, I get a blank page with the message: Please wait while loading... and it...
Hello, I had similar problem with 2Big Network2 which was freezing the same way. I know the question is old but maybe someone will find this answer useful.
I solved the problem by updating the firmware. It may seem trivial but it took some time to figure out how to do it right.
My firmware was 1.3.7 and I was unable to easily get SSH access.
To upgrade the disk you have to
1. get it recognizable by Lacie Network Assistant. If you have a fixed IP it may not see the disk. To switch your device to DHCP assigned IP you have to reset it to factory settings (without losing data). Procedure from LaCie site works (http://manuals.lacie.com/en/manuals/d2-2big-5big-network2/reset)
  1. Make sure the product is turned OFF.
  2. Press and hold down the front button. Without releasing the front button, turn the product on by pressing the power switch on the rear of the product.
  3. Keep the front button pressed until the front LED becomes solid red, then release it. (The LED should become solid red about 10 seconds after you turn on the product.)
  4. The front LED will blink blue. When it becomes static blue, press the front button once within 5 seconds to confirm reset.
  5. If any of the steps are omitted, the product will boot normally without resetting.
2. you need the LaCie Network Assistant which you can download from here http://www.lacie.com/support/drivers/driver.htm?id=10138
I used 1.5.15 version for windows
3. Once you have the LNA installed it should recognize the disk. However if it doesn't start and says you are missing bonjour service just go to the installation directory and install bonjour.msi
4. At this point you should be able to start LNA which finds your drive. Now you need firmware (capsule file). You can't just load the newest firmware out there. Given fw version can be applied only to certain previous revisions. To check which version you need you have to check your current release. To get your current release open LNA and go to Configuration tab. The current system version is displayed in the bottom-left corner.
I updated mine to next release (from 1.3.7 to 2.0.5).
5. Now you should now to which release you should update. The question is where to get the firmware from if the LaCie support page (http://www.lacie.com/fi/support/drivers/driver.htm?id=10201) does not contain the one you need ? You can use and ftp service (it's not obvious).
Go to ftp://2bignetwork2-update.lacie.com/ (just put this address in files explorer address field) and login with 2bignetwork2 user and 2bignetwork2 password. Then browse for firmware.
6. now assuming you have successfully downloaded the firmware open LNA go to configuration tab and click "Update your NAS.." button. Authenticate with admin user and admin password then browse for the capsule file and begin updating
7. drive will need couple minutes to finish (blinking blue-red) then it will restart and when the light turns solid blue you should be able to get access to the web administration interface.
As other suggested - if you don't want to risk losing data get disk(s) (if in RAID0) and use some linux box or VM to backup data.
Jul 22, 2011 | LaCie d2 Network 2 NAS server (301505)...
I cant see my external lacie hard drive on my mac with the Lacie Network Assistant. The hard drive is visible with the finder though. With the dashboard and with the finder I am able to move or copy files...
for the product that you selected for your question, it is impossible for the LaCie Network Assistant to see it because it is a Local drive (USB).
The LaCie Network Assistant only detects the Network LaCie drives.
Regards,
Jan 25, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie NAS doesn't appear in network
Have you installed the lacie network assistant?
Jan 23, 2010 | LaCie Ethernet Disk (300788) 1000 GB...
PC no longer recognises LaCie drive
Hi Katya!
There are several possible causes for this. You didn't specify if you're running Windows or Mac so I apologize in advance if some of the information I provide does not apply.
  1. If you recently performed a Windows Update, there's a patch to fix your issue; http://support.microsoft.com/kb/925196#fixit4me
  2. There is a firmware upgrade for your external hard drive. It is located here: http://www.lacie.com/ca/support/drivers/index.htm?id=10007
  3. If the above solutions don't solve your problem, you may try uninstalling the device and reinstalling it. This should clear any communications errors it may have
I do hope I was able to solve your issue. I wish you the best of luck.
Greg
Jun 12, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Installation of Lightscribe
Loreen:
Check out this link, make sure that the software/tool or utilities are compatible to PC vista, please also check any firmware as well:
http://www.lacie.com/support/drivers/index.htm?id=10008
In Vista after the download is complete you might have to do this:
right click over the file and select run as administrator, (its strange but it depends upon the user trying to install software on your system).
Hope it helped!
Regards
Dec 16, 2007 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
