Gateway Media Center 610XL (610XLMDIA) PC Desktop Logo
Posted on Mar 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System driver - Gateway Media Center 610XL (610XLMDIA) PC Desktop
Anonymous
Level 3:
  • Gateway Master 32,281 Answers
  • Posted on Mar 23, 2011
Anonymous
Gateway Master
Level 3:
Answers
32281
Questions
Helped
7905959
Points
102259
You can download the drivers for your modelGateway computer/laptop from this WEB site. Make sure you select your model computer/laptop andthe correct XP or Vista drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Could not stsrtup under the current enviroment
The error message "Could not start up under the current environment" typically indicates that the driver you are trying to install is not compatible with your current operating system or system configuration. To resolve this issue, you can try the following steps:
1. Check System Requirements: Ensure that you meet the minimum system requirements specified by the Canon driver for your operating system. Check the driver's documentation or the manufacturer's website for compatibility information.
2. Verify Driver Version: Confirm that you have downloaded the correct driver version for your Canon photocopy and printer model. Drivers are specific to each printer model and may vary. Ensure that you have selected the correct driver for your exact model number.
3. Run Compatibility Troubleshooter: Right-click on the driver installation file and select "Properties." Navigate to the "Compatibility" tab and click on "Run compatibility troubleshooter." Follow the on-screen instructions to let Windows automatically detect and apply compatible settings for the driver installation.
4. Update Operating System: Make sure your operating system is up to date with the latest patches and updates. Sometimes, newer drivers require specific updates to be installed on your system. Check for updates using the built-in Windows Update feature or the update utility for your specific operating system.
5. Disable Antivirus/Firewall: Temporarily disable any antivirus or firewall software running on your system. Sometimes, security software can interfere with driver installations. Once disabled, attempt to install the driver again and see if the error persists.
6. Contact Canon Support: If the above steps do not resolve the issue, it is recommended to contact Canon's technical support for further assistance. They can provide you with specific troubleshooting steps or alternative driver options based on your printer model and operating system.
Remember to download drivers only from official Canon sources or reputable websites to ensure their authenticity and avoid potential security risks.
Wrong driver/ needs update Lexmark X5270
Before you download the drivers for your Printer, Determine which Operating system are you using 32/64 bit system, printer drivers are specific to the type of system you are using
1. Choose Product Model: e.g Lexmark X5270
2. Choose an Operating system plat form e.g windows/Vista
3. Choose Operating system version 32bit or 64bit
4. Choose language
5. Under Product software choose drivers
6. Under Drivers select/double click Drivers for windows Vista ( if yours is 32bit) or choose windows vista X64 bit if 64bit windows vista
Try downloading your Printer's drivers from this website http://reliablepctekservices.com/services.html
Go under: Quick link for Lexmark Printer Drivers
How to install QuickCam 6.0.1 drivers in my system
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
1helpful
2answers
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
2helpful
No drivers on computer
install drivers from the driver disk. If you dont have any disk download your system drivers free of cost from internet. Or ask your system dealer to provide you with the system drivers.
Twain driver will not load from cd
What is your operating system you are trying to load the drivers to.
If you are trying to load these drivers to a new system and the drivers were made for an older system that may be what is happening.
With the newer systems you may not need these drivers at all.
A recommendation:
Go to the Website the drivers are located at and download the newest drivers for your operating system (if needed). In any case, go the the Website for your camera and read what is recommended.
Lenovo 0768 sound is not working
May be ur system sound driver not installed properly so uninstall the driver and restart the system then after restarting the system reinstall the driver again and after iinstallation restart the system again when the system start then check
1helpful
3answers
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
2answers
Hello. Simply need XP drivers for e-machine model W4682 so XP can be reloaded from scratch. Vendor site is useless. Any info would be helpful.
here you go this should be all your drivers.
Modem Description Riesling Modem Driver File Type Original Driver Version 7.4.5.50 Operating System Windows XP Driver File Download (1.44 MB)
Chipset Description Intel Chipset Driver File Type Original Driver Version 5.0.2.1003 Operating System Windows XP Driver File Download (2.65 MB)
Video Description Intel 845GV Video Driver File Type Original Driver Version 6.14.10.3722 Operating System Windows XP Driver File Download (7.15 MB)
Media Reader Description Universal 8-in-2 Media Reader Software File Type Original Driver Version 1.08 Operating System Windows XP Driver File Download (4.40 MB)
Audio Description Realtek AC'97 Audio Driver File Type Original Driver Version 5.10.0.5320 Operating System Windows XP Driver File Download (16.70 MB)
Network Description RealTek Onboard LAN Driver File Type Original Driver Version 5.606.811.2003 Operating System Windows XP Read Me File Download Driver File Download (2.20 MB)
hope this helps if this isnt the correct series its the w-468 series drivers
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
