Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
I have a 50cc suzuki quad, it starts and goes, but on full throttle the motor boggs down as if it is running out of fuel, any ideas ?
    Problem Solver:
  • 7 Answers
  • A carburetor is essentially a tube.
  • There is an adjustable plate across the tube called the throttle plate that controls how much air can flow through the tube.
  • At some point in the tube there is a narrowing, called the venturi, and in this narrowing a vacuum is created.
  • In this narrowing there is a hole, called a jet, that lets the vacuum draw in fuel.
Try looking to see if theres's a crimp or a kink in your lines. If there is, then opening the throttle allows more fuel into the line than is capable of passing through the jet and it could cause a backflow actually lessening the amount of fuel going in. Since the carburator actually controls the amount of air and fuel needed to, "Fire" the engine a lessening of fuel can cause an improper balance of fuel + air. This could be your problem.
Posted on Mar 23, 2011
Could also be overheating because of improper fuel mix/oil .yesterday had a nephew put straight gas in my machine and this happened.it heats up quickly thereby bogging down,most likely has a broken piston ring.Make sure its not overheating before you go crazy with fuel system..other than the obvious..i.e. fuel restriction.
Posted on Oct 17, 2011
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
1992 60 hp motor bogs under full power????
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
Jul 24, 2014 | Seloc Johnson Evinrude Outboards 65-300HP...
I have a 2008 suzuki ltz250 quad sport and it bogs out and dies at full throttle
sounds like a feul delivery problem check your filter and the petcock .pull the feul hose at the carb . could also be that your feul tank is not venting properly
May 09, 2012 | Motorcycles
50cc moped runs great until full throttle then boggs down-does not do it at 1/2 or 3/4 throttle
Check for good fuel flow to carburator. If so have a qualified technician look in the carb for debris blocking the main jet. this is very common when the vehicle sits for an extended period of time.
Dec 28, 2011 | RTO Gas Motor Scooter 50cc
Got a kazuma 50cc quad have problem starting it when i finally get it going it wont take any throttle without cutting out.
i have i 50cc ATV quad and we have done every think to it and it still won't start but the fuel isn't going to the spark plug any one know what to do. ?
Jan 09, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
757 people viewed this question
Top Quad Cycling Experts
Marvin
Marvin
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
