Question about Acer Aspire Predator (AG7750U2222) PC Desktop
Just bought the acer g5900.Memory DDR3 what i want to know is whats the MHZ 1066 or more.
  • 31 Answers
MHZ is the speed of the RAM, this is very important to know because all RAM in a computer MUST be the same speed. In example that a 800 MHZ RAM cannot work together with a 1066 MHZ RAM, otherwise the computer will not boot.
Posted on Mar 23, 2011
Can i install 4 GB RAM for acer G41T-AD V:1.0 motherboard?
Yes. The specs are
2 x 240-pin DDR3 DIMM slots Supports Dual Channel DDR3 1333/1066 MHz non-ECC, un-buffered memory (Max 4GB)
Jan 07, 2015 | Acer Computers & Internet
HP pc 1 short beep 1 long beep?
https://support.hp.com/us-en/document/c02222922
is the coin cell , 3v? or 2v , 2.9v and up is good, lower not.
the memory rules on all PCs is complex , just because it fits means nothing.
2010 PC DT
windows 7 32bit?
do all PSU voltages read correct with a voltmeter?
they must be in spec,.
memory
240pin DDR3 DIMM 800MHz Memory
low density only maybe a limit here.
so you want 8GB up
2GB per slot.
there are 3 kinds on voltage alone, low, high and both
then speed,
sure forum factor DDR3 240s
but there are density limits and socket max limits and system max limits
if running windows 7, 32bit its limited to 3.5? GB.
so 8 is a waste there.
if running windows 7, 64bit then it can use full memory.
if the bios allows it
and the Processor MMC chip allows it.
see? there are complex limits on all PCs.
in this case AMD processor.
Athlon II X4
limits on this mobo are.
HP spec page
Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
  • Supports Dual channel memory architecture
  • Supported speeds
    • PC3-10600 @ 1333 MHz*
    • PC3-8500 @ 1066 MHz *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
  • Non-ECC memory only, unbuffered
  • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
  • Supports up to 4 GB* on 32-bit PCs
so what memory did you buy, and from whom.
name make model numbers exactly.
I think its coin Cell bad
or PSU bad , not memory.
if one stick fails its not that stick if
you now are buried in sticks, if all sticks fail in just slot
its not memory prob. its power.
for sure all original stick fail as one.
Mar 04, 2017 | HEWLETT-PACKARD Pavilion p6514f PC Desktop
I have a lenova 9704-A36 pc with vista installed came with 1gb of ram. Want to upgrade, where to find compatible memory
52757437-260x260-0-0_lenovo+2gb+pc3+8500+1067mhz+ddr3+ecc+sdram+memory.jpg Mouseover to zoom or click to enlarge Lenovo DDR3 2 GB SDRAM (41U5252) $57.00 1 store
  • Technology: SDRAM
  • Form Factor: DIMM 240-pin
  • Capacity: 2 GB
  • Modules Qty: 1
  • Bus Clock: 1066 MHz
ahr0cdovl3d3dy5jb21wdxrlcnnzywxllmnvbs5hds9zag93aw1hz2uucghwp3byb2r1y3q9mtaznzgmaw1hz2u9mcz0exblpwxhcmdl==.jpg
Lenovo 1GB DDR3-1066 Memory Module for Notebooks
Improve overall performance of ThinkPad systems by upgrading with additional memory. PC3-8500 DDR3-1066 low-halogen SODIMM memory offers maximum data transfer rates up to 1066MB/sec(1) to help you increased performance of memory intensive applications such as streaming video, graphics and CAD programs. Adding more system memory is one of the least expensive ways to help boost overall notebook system performance and allows more multitasking which saves time and hassle.
May 02, 2012 | Lenovo Computers & Internet
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
    You may have tried to put too much memory (RAM) onto it.
    That models maximum spec is:
    Memory upgrade information:
    • Four DDR3 DIMM (240-pin) sockets
    • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
    • Supported speeds
    • Supports up to 4 GB on 32-bit PCs
    You can find the specs and troubleshooting help files here
    Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
    Acer AS4745G-542G50Mnks i want to see the specification of that unit
    Description • Intel Core i5-450M (3MB L3 Cache, 2.40GHz with Turbo Boost up to 2.66, DDR3 1066 MHz, 35w) 64 archietechture,Smart Cache
    • Mobile Intel HM55 Express Chipset
    • 2GB DDR3 memory
    • 500 GB SATA HDD
    • ATI Mobility Radeon HD 5470 w/switchable Graphics Technology upto 3579 MA of Hypermemory
    • 6 cell Li-ion Battery pack
    • 14\"HD 1366x768 pixel resolution, high brightness (200-nit) Acer CineCrystal LED Backlit
    Specification • 8x Super Multi Double-Layer Driver
    • 2.23KG weight
    • LAN: Gigabit Ehternet, WPAN: Bluetooth 3 USB 2.0 ports
    • Acer Crystal Eye Webcam;
    • 802.11b/g/n WiFi Certified
    • Built in Multi-in-one card reader
    • Built in Bluetooth
    • 1 Year Limited Local Warranty
    • Acer Carrying Case
    • Windows 7 Starter
    Feb 05, 2011 | Acer Computers & Internet
    Want to add ddr3 memory to my p5qc board
    Hello
    The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
    DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
    2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
    Hope this helps
    Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
    I need to know which is the part number of the DDR3 bulded iside the Lenovo ThinkPad Edge 15 0301-GQG leptop?
    Manufacturer Part: 55Y3706
    2 GB (installed) / 4 GB (max) - DDR3 SDRAM - 1066 MHz - PC3-8500 ( 1 x 2 GB )
    So you need DDR3 SDRAM at 1066Nhz PC3-8500
    If you are running 64bit Software then upgrade to 8GB (2 X 4GB sticks) otherwise your OS may not recognise any more that 2 MB
    c0006679.jpg LenovoMemory - 1 GB - SO DIMM 204-pin - DDR3 - 1066 MHz / PC3-8500 - 1.5 V - unbuffered - non-ECC Manufacturer Part: 55Y3706
    Jan 04, 2011 | Computers & Internet
    I have gigabyte motherboard H57M-USB3 with Inter core i5-760 processor and kingston k24-7070 1333Mhz memory card which is not working. are they compatible? what can i do to make it work?
    It should be, it says this about your memory support.
  • 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
  • DDR3 2200+/1800/1600/1333/1066/800 MHz
  • Here is a list of compatible memory for that motherboard
    http://memoryselector.cnetchannel.com/tigerdirect/results.asp?hvhBlBE0fe0AED
    Aug 31, 2010 | Gigabyte GAH57MUSB3 Motherboard
    DDR3 RAM
    According to your description you have 4 memory slots and each memory slot can hold
    DDR2 PC2-6400
    DDR2 PC2-8500
    DDR2 PC2-5300 with a maximum of 2GB per slot.
    This board does not support DDR3.
    I hope this helps your memory question.
    May 01, 2009 | Acer Computers & Internet
    Acer Aspire Predator (AG7750U2222) PC Desktop Logo
    79 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
