Question about Pioneer VSX-D606S Receiver
Dear expert I am the Israeli distributor for Paradigm, MartinLogan, Anthem and more. I have a customer who has the Pioneer VSX-D606S that the subout is not working. He does not have the manual and even if I spent a lot of time trying all posibilities in te remot control, I could not enter the correct place to activate the sub out. We are connecting the DVD to the Pioneer via the digital RCA output of the DVD to the input of the Pioneer. I see on the front display the the little square with the "sub" wording is there but no sound. Even when I try to rais the sub volume, there is no reaction from the Pioneer. I hope it not too dificult for you to help. Best wishes Mr. Moshe Levy, manager L. M. Agencies & Marketing Israel 8 Hess street, Rishon Lezion 75218 Israel moshelvy@012.net.il
    Brigadier General:
  • 8,546 Answers
I can't find a free manual to quote.
There are three parts to this scenario and only one named.
First, you need to set the receiver up with speaker definitions and capacities, subwoofer presence, bass management and Test Tones to verify it CAN make each speaker work.
The DVD player has a piece of this, too. It probably has a menu for speaker configuration that needs to be set up. And its digital output prbably has a setting like DTS/Dolby Digital/PCM. Look in the manual. Look in the manual.
Then there's the sub itself. Is IT working? Jack it into any other pre-out as a test.
Posted on Mar 23, 2011
How many fuses are on my pioneer reciver vsx-d606s?
1 for the power supply and 1 for left and 1 for right channel, but every stage inside has also fuse-resistors resistors with a extra function to protect some components that are resistors the are mounted higher or different on the print .
Nov 04, 2015 | Pioneer Audio Players & Recorders
Adjust speakers without remote
usually you can cycle though the settings on the front of your amp, using the jog dial. If not possible contact company for replacement remote. But I can do everything on the front of my receiver. By the number of buttond on this model you should be able to.
Dec 09, 2012 | Pioneer VSX-D606S Receiver
Pioneer 606 overload
Check the speaker wires on the back for shorts, no issues! suspect audio output problem in the pioneer, serviceman recommended.
Jul 01, 2012 | Pioneer VSX-D606S Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
PIONEER VSX-D606S WHEN POWERED STAYS IN STANDBY MODE- LIGHT IS ON, A CLICK IS HEARD BUT THAT IS ALL
Your unit staying in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.....
Apr 17, 2011 | Pioneer VSX-D606S Receiver
I forgot how to turn on the sub on my VSX D606S
There may be a switch to turn or a botton.
May 29, 2010 | Pioneer VSX-D606S Receiver
User manual....
go to google and type the model number, you will find it but you have to pay about $20.00
Oct 28, 2008 | Pioneer VSX-D606S Receiver
Pioneer VSX-D606S subwoofer set up
is the square button also labled as down arrow button, push the down arrow button and will give access to the lcd screen setup options on the receiver center speaker size lfe att settings cross over rear channel size ect. i don't have the manual either took me a year to fix the issue.
Jan 24, 2007 | Pioneer VSX-D606S Receiver
Pioneer VSX-D606S Receiver Logo
126 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
