Question about Vacuums
Was frying chicken drumsticks @190 degrees approx and it switched itself off and won't come back on.
  • northclif651 Mar 23, 2011
    G'day, 'Bellini' - Model No BTDF60
  • northclif651 Mar 24, 2011
    Yes very simple. Shame it only lasted a few months but thanks for your answer and confirming my own thoughts.
  • Vacuums Master
  • 11,800 Answers
This is a very simple deep fryer: the entire electrical installation is composed of an power cord, a power switch, a thermostat, an control board with a timer and an heating resistance.
If it doesn't comes on then one of the components has failed. Check the resistance first, then the thermostat and finally the power switch. If all are good then the board has failed. Unfortunately the only ones that have spares for it are the manufacturer and the certified repair shops - you will have to contact the ones that sold it to you and they will put you in contact with them.
Posted on Mar 23, 2011
    President:
  • 1,961 Answers
Hello!
brand and model number of your unit please?
Head won't work on dc 11
1) test the outlet wall with another devide such LAMP, if work is o.k
2) the problem will vacuum power : a) test the switch b) motor itself repair or replace.
God bless you
Sep 27, 2012 | Dyson DC11 All Floors Bagless Canister...
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
How long to cook chicken sausage on the George foreman
this depends on how thick the sausages are. For sausages that are about 1 - 1 1/2 inches thick it will take about 10-15 minutes. the best way to tell if a sausage is done (chicken or pork) is to insert a meat thermometer into the end of the sausage about 3 inches deep. When the meat is done it will read 160 deg F.
May 03, 2011 | Vacuums
T Fal fry expert manual
My friend give a Fry expert but haven't manual. I don't know how long to fry chicken leg or fried. Could you provide to me?
Oct 25, 2010 | Vacuums
I cant use the hose
There will be a dial on top of the tank that you can rotate 180 degrees which will switch the unit from vacuum to hose.
To switch it back to vacuum, rotate the dial back 180 degrees.
May 20, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I jammed a deodorant cap into the entry hard plastic part of the hose. can I open that up to get it out?
What goes into a vac hose enters the smallest part. The handle is designed to be a small reducer to prevent some blockage so the obstruction must back out. Do not attempt to use a sharp coathanger as you could tear the inside of t the hose and do not attempt to push the cover deeper as it will wedge tight. Your best bet is to draw this item back out with another vac. Sometimes bumping,( not smashing) the side of the handle against a carpeted floor area while doing so will help dislodge the item. Failing that you will need to open the handle itself.
If you look closely on this hose there are several small screw covers which will pop out with a pin to reveal hidden screws. Once removed the handle will open like a **** shell and then slide off the hose. The handle must be carefully aligned when reinstalling and the wire covers installed last, with the handle fully in place.
If all else fails and you must use a wire coat hanger, create a small 190 degree hook at the end so there is no chance of a sharp edge cutting the hose itself if pushed to far. Post back with results or if you need more help
Oct 28, 2009 | Electrolux Guardian Bagged Canister Vacuum
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
Replace switch on electrolux 2100
The 2100 is an older model which is prone to rocker switch failure. What you see outside is only a switch button. Underneath is a plastic rocker which sits in a grove and pivots back and forth to activate the on off switch.
If you push the switch down and there is no audible "click" you Likely need the rocker itself, especially if you tip the vac upside down and shake it and hear a piece rattling inside or find a broken narrow plastic finger about 1/2" inch long when opened.
However if it clicks and works every 3-5 times,the rocker is fine and you will need the spring mechanism and switch button which you can see form outside.
To remove either the process is the same.
Separate the body by opening the bag cage and pulling the two bumpers forward with a set of pliers. They are locking keys. Once removed, the rear housing will drop off allowing the vac to hinge open back to front. Do this with the vac laying upside down and observe the hinge section of the front bag door .DO NOT REMOVE THE MOTOR. You will need to clip all these componnets back together to reassemble and slide the bag chamber back to seat against the motor with the motor housing engage in the ribbing of the vac side walls.
With the vac open you will only need to remove the spring loaded bag lockout switch and the bag housing it sits on, not the motor or rewind..
Once removed there will be 6 chrome philips screws visible. These hold the top trim on the front of the vac and the front ones hold the on off switch into its housing. At the very front will be two screws going through a black or whitish switch housing. That housing will lift out with wires attached to reveal the switch rocker, etc,. This portion will lift back and out at about 45 degrees of the inner housing, as a unit. The switch button sits atop the rocker via two end tabs and will pop off the housing to reveal if the rocker itself has a broken "finger" or if the button has a weak spring.
The suspect spring is not the coil rocker spring but the thin U shaped spring on the underside of the switch button. Remove the rocker spring with a pair of needle nose pliers.and examine the rocker comparing to your new one.Use more vaseline on the new rocker and if you have it reinsert the clear flex plastic into the coil spring. If not disregard.
Re-installation is the reverse order, tuck switch back in at 45 degrees from back to front.
Pay special attention the the rubber seal at the back of the bag cage.
If anything is misaligned in this body you will fight to reassemble. Don't fight it , back up and look at your work. When and ONLY when it is perfect it will realign and click together like a lego set and the keys will slide in perfectly
You can and should test the vac before reassembling the whole body, simpley slide your hand under neath and activate the switch, with a bag inside the vac.
See now, wasn't that EASY???????
Please post back to advise how you make out. Its a 7 minute process worth $25 for a good tech. A bad tech will spend half a day trying to figure this one out but just go slow and follow the instructions and you will do fine.
Oct 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Kenmore canister switch issue
It most likely is the hose pcb. It has the switch on it, and part of it is either just dirty or bad.
May 17, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
