Question about Gaggia Platinum Vogue 90800 Espresso Machine
2 issues 1. coffee will not dispense in measured amounts. need to physically press the 'cup' button when you want it to stop dispensing coffee. 2. descalling light on. have descalled for nearly 2 hours and light will still not go out. unit is about 1 year old. thanks.
  • johnd702 Mar 23, 2011
    thanks but problem 2 occurred before problem 1.
    I only dissolved descaler in water container and followed instructions of manual.
    President:
  • 2,080 Answers
For the pour volume problem, try HOLDING DOWN the button next time you are dispensing a drink and then only let go of that button just when the liquid gets to the desired level.
Often times this action serves to reset the memory of the unit so that it will dispense the new amount that you just set from that point on when you push the button once as you normally do.
Good luck, hope that helps.
Posted on Mar 23, 2011
    Brigadier General:
  • 3,513 Answers
Hi
It's a malfunction of your espresso machine, while descaling your machine you must have fumbled with the inner mechanism, which is creating such kind of malfunction. It is suggested to contact the customer care.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Pasquini Livia 90 Auto Dose Panel
First, I'm not a Pasquini tech, but I have worked on several similar brands.
* Most Semi-automatic machines will usually have the program button on the same as the stop button. Some will program all the groups at once or can be individually set up for different pours (shots)
* Holding down the program or stop button for 5-10 seconds will activate the program mode. Note that if you don't press any dosing buttons after 5-10 seconds the program mode will revert to normal mode. Some may cancel out the previous dose set up.
* Before starting, determine what you want a shot to look like. 1 oz, 1.5 oz, 2 oz., etc.
* Set up your portafilter with ground coffee. DONOT change the grind size once your satisfied with the QUALITY of pour (don't confuse this with the amount of the dose. This is handled with the programing of dose water.) Water is absorbed by the grounds depending on the grind size and some times the amount. Pods are different from loose ground coffee too.
* Load up portafilter and place measuring cup(s) under spout(s).
* Press program button and hold for 5-10 seconds. The button will light and stay on (some blink).
* Press the dose button for the appropriate portafilter you have mounted. The pasquini requires you to press the stop/program button once you have achived the desired dose. Other brands require the dose button to be press and held down until the amount of dose water is reached. Letting go button logs the amount in but only after pressing the stop button does it set.
* For other brands, you may need to set up all buttons prior to pressing the program/stop button to confirm dosing of all buttons.
* Remember to keep reloading fresh coffee grounds in the portafilter for each adjustment. Used (wet) coffee will throw out the water dose calibration.
Aloha, ukeboy57
PS; I found a good video from Whole Latte Love site:
https://www.youtube.com/watch?v=1NGN55nYBxQ
Mar 11, 2018 | Pasquini Coffee Makers & Espresso Machines
Machine turns off too soon
The buttons on the machine are programmable. You've likely inadvertently reprogrammed the button.
Hold the button in until the correct amount of beverage has been dispensed. After that, pressing and releasing the button will dispense the set amount of liquid.
Mar 29, 2008 | Nespresso D290 Espresso Machine
How do i use the dolce gusto i put a pod in of chocolate and the machine just kept going it wouldnt stop when tje cup was full
I'm not familiar with that model but oftentimes programming the quantity of water will involve pressing and continuing to hold the button down until the desired quantity of water has been dispensed. Next time you press and release the button and it should stop when that same quantity is in the cup because you holding the button last time has programmed it for that amount.
Jan 12, 2017 | Krups Nescafe Dolce Gusto
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Jun 15, 2015 | Gaggia Brera Coffee Maker
Won't dispense all the coffee from the disc. Have to push button at least two times. Descaled Help
The discs tell the machine how much water to dispense through the disc. Some discs dispense a small amount for an Espresso, others give a larger drink. Normal cups will not fill, you need smaller coffee cups for most Tassimo drinks.
Check the packet to see how much it dispenses and check with a measurement jug to see if it is working properly, you may be surprised to find it is working fine.
Oct 03, 2014 | Bosch TASSIMO Coffee Makers & Espresso...
Why can't i get cup size in capresso impressa?
Hold the button in, until it says "Enough?" then release..
When you have the right amount, push the button again.
Jul 06, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
At first my Miele CM5000 worked perfectly. When I pressed the espresso button, a perfect espresso would come out- the machine dispensed the correct amount of liquid then stopped automatically. Now, the...
If the espresso coffee outputs too much water and doesn't stop, there is an easy fix. The quantity adjustment for the machine is off. After looking through the user manual, I found out that you could press and hold the espresso button, and then follow the on-screen instructions where you can specify the quantity poured.
Aug 03, 2013 | Miele Cm 5000
Does the coffee and water come automatically out of the coffee dispenser or do top up with water after coffee has been dispensed
It comes out together. You can adjust the amount by holding down the coffee button when making coffee and release it when it reaches the desire quantity.Can be adjusted on all three cups individually.
Jan 24, 2010 | Saeco Royal Professional Espresso Machine
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Gaggia Platinum Vogue 90800 Espresso Machine Logo
122 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
