Question about Zanussi Washing Machines
I cant get my washing machine to set a programme model 1600 aquacycle
    Brigadier General:
  • 6,277 Answers
(Try this but no promises!)
Sorry but I do not know your particular machine BUT I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 23, 2011
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
I use Zanussi 1600 Aquacycle 5.5KG. When washing, water is always coming out and the floow always wet.
either the drum seal has a split or hole in it,or the same applies to the rest of the hoses,check the outlet pipe to see if is blocked or not,if not, unless you are prepaired to take the machine to peices youself,call the repair man.ps you did not say how old it was,or if it is still under warentry.
Jul 06, 2011 | Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
My zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Feb 24, 2010 | Washing Machines
I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200 XC6 WASHING MACHINE FX1265W TO ENABLE ME TO IDENTIFY THE DIFFERENT PROGRAMME SYMBOLS THE PRODUCT NO.IS 91479270300 TYPE F6857648 CAN YOU HELP
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Nov 29, 2009 | Zanussi Washing Machines
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi aquacycle 1600 washing machine..cannot remove the filter at the front
prise it out with two flat screwdrivers you may have to use a pliers .good Luck
Dec 01, 2007 | Zanussi FLE1416W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
