Question about Fisher and Paykel Washing Machines
When the machine spins it begins banging and stops...it has been balanced by machine mechanic and had pump replaced...when I rearrange clothes several times I may be lucky enough to get it to finish spin cycle, but that is not very often...i am pulling my hair out - its sooo frustrating...any advice would be very appreciated. Cheers, Lesley
    Brigadier General:
  • 6,277 Answers
Although you say 'it has been balanced by machine mechanic' I would STILL recommend you try my method below to make absolutely certain before considering something else.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Mar 23, 2011
Always out of balance
out of balance is from the tub not level and or the air dampeners on the ends of the suspension rods are broken( top loader machines ---machine type not stated --
if it is a top loader and you laid it on its side , it is possible that the tub is now not level and the dampeners have been damaged
Oct 23, 2017 | Washing Machines
Going out of balance
could be the springs are wearing out. some haier models I have seen start the spin at full motor speed, which could be part of the problem.
Nov 20, 2013 | Haier Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
It won't spin or do anything, it will only fill, last night it started banging during the spin cycle now it doesn't make any noise at all
I would need a little more infor. - but when your machine bangs on the spin cycle, it usually means your load is unbalanced. So lift open your machine and balance out your clothes. This should clear this up. You see this problem more with heavier loads (eg. towels, jeans, heavy garments, etc.). I try and balance out my laundry as I put it in the machine. It helps a bit, but even so, I still at times have to go balance it out manually. I hope this helps, but if not - then there's some other question's I would ask, but that's where I mentioned needing more info. at the beginning. Good Luck!
Dec 28, 2009 | Kenmore 22622 Top Load Washer
Banging loudly on spin cycle . machine is leveled and clothes are equally distributed
Machine is level but the load isn't.rearrange the clothes to balance the weight in the machine.
Dec 14, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Went out of balance
it most likely pulled one of the hoses loose on the underside of the tub ,,, pull off front and check all the hoses / larry
Dec 08, 2008 | Maytag PAV2300 Top Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Banging during spin cycle
Its possible that a spring has broken, become overstretched, or otherwise failed. Also there is a delrin ring called a snubber that the tub moves on (between the base of the machine and the frame of the tub) it wears out and causes this complaint. I also recommend new springs with a snubber. However replacing a snubber is quite tricky and you will probably need a Tech for that.
Dec 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
